Bearings?
Old Sep 9, 2007 | 10:56 PM
flynlow3's Avatar
Default Bearings?
I have 75,xxx miles on this ls1 and have the motor pulled for a heads cam swap. When I pulled the cam, It had a little wear from two of the bearings. #2 and 3. I have decided that I have a lot of work into this car since i upgraded the suspention, rebuilt tranny,brakes, exhaust, intake ect.. that I didnt want to half *** it! Since I have the motor out and oil pan off, I think its a good idea to have the block hot tanked, honed and new bearings put in right?
What it boils down to, What bearings are recommended? I have searched and read as much as I can find thus far. I know I want coated bearings because I want them to last. Give me some feedback guy.
Jeff
Old Sep 9, 2007 | 11:14 PM
njc.corp's Avatar
depends what hp u want-race,daily driver etc-- and what u can afford-
Old Sep 9, 2007 | 11:25 PM
the_merv's Avatar
Clevite 77 H-Series.
Old Sep 9, 2007 | 11:27 PM
flynlow3's Avatar
I have hot cam, 5.3 heads ported polished with 1.8 stainless roller rockers. Comp chromoly push rods 915 springs ect. Intake and exhaust as well. This is it. Not sure what kind of power im putting down but I want to be able to start it up and drive it and not worry about it. Looking for reliability mainly. I want to motor to last with what I have done to it.
Old Sep 10, 2007 | 12:08 PM
flynlow3's Avatar
anyone else wanna throw an opinion in before I purchase these?
Old Sep 10, 2007 | 05:04 PM
LS1Formula01's Avatar
77 H series
Old Sep 10, 2007 | 05:06 PM
i have 79xxx miles and am getting ready to tear my motor down and freshen everything up. also doing the ls6 pcv conversion because the ls1 pcv system went to sh*t on my motor.
Old Sep 10, 2007 | 06:09 PM
3.4camaro's Avatar
I dont think you need to rebuild it if it isn't broke. Rebuilding an engine is only worth the time/money if you broke something, or are building a badass engine.
Old Sep 10, 2007 | 07:58 PM
flynlow3's Avatar
Well its not what you guys would call bad *** im sure but it is going to have a decent power upgrade and be reliable
Old Sep 10, 2007 | 10:59 PM
N2DP2QT's Avatar
clevite 77 H-series definitely
Old Sep 10, 2007 | 11:23 PM
5_02ls1's Avatar
clevite 77 h series...go ahead and do rod bolts while your in therer
