need some help with somehting...
Old Sep 18, 2007 | 04:47 PM
transamfreak01's Avatar
Default need some help with somehting...
i am thinking about doing a stroker kit this winter. i am looking to do a 383. i would just like to know whats good (part wise) and about how much will need to be put into this and what do i have to change. thanks a lot
Old Sep 18, 2007 | 04:49 PM
oh yeah and ill be hitting the car with probably a 2 stage kit, 150 and then a 100. not really worried about dyno numbers
Old Sep 18, 2007 | 05:55 PM
silver01z06's Avatar
eagle rods and crank are priced well and are good parts. lots of pistons out there to chose from. if you want to spend alot of money look at stuff from lunati or callies(sp)
why only a 383? if you are buying a crank why not go with a 4 inch bore and get more cubes. the only additional cost would be the block.
Old Sep 18, 2007 | 07:23 PM
well i really dont want to spend the money on another block. thats why i was thinkin of doing a 383 stroker with mine. but like i said i no nothing about this and i have been tryin to learn but its not coming to great. so i need a list of what would work with prices. thanks
Old Sep 19, 2007 | 09:03 AM
thunderstruck's Avatar
6 liter blocks can be had for as little as 300
Old Sep 19, 2007 | 11:18 AM
PunkerPontiac's Avatar
Where from? i'm looking into building a 408 in the future
Old Sep 19, 2007 | 12:31 PM
and if i use the other block everything else will bolt up
Old Sep 19, 2007 | 12:44 PM
blueeyeddevil141's Avatar
Yes, get the 6.0, everything will bolt up, you'll need a few minor things.
Old Sep 19, 2007 | 11:31 PM
ok and any certain place to get this at???? and should this put out more power than the 383?
