dart heads. which plugs?
Q: What kind of spark plugs should I use with my new Dart heads?
A: 3/4" reach gasketed plugs in the correct heat range for your application. Consult the manufacturer for heat range information.
Tr- 55's
14mm, .708"(18mm) reach tapered seat
http://www.ngk.com/search_char.asp?t...=37&action.y=7
FR5 rings a bell but they are gapped .39
the FR5's are 3/4 reach gasketed. but are factory gapped at .39 not sure if theese are the right heat range. Autolite 3924's are the same specs. Am i looking at the right plugs?
