Cracked block?
Old Sep 22, 2007 | 12:41 AM
blueeyeddevil141's Avatar
Default Cracked block?
As I was reassembling my motor, I began to tighten down the head bolts, and they got hard to turn, and then the pressure relieved and they turned fine, and it made a small vaacum sound. And a small amount of coolant started to come out of the side of the block(very small). It has come to my attention that it may/probably is cracked.
Is this for sure? If so, how do I fix this, aside from replacing the block.
Old Sep 22, 2007 | 12:42 AM
JMBLOWNWS6's Avatar
Well it sound like you compressed water in the threads and cracked the block. No fix for it. Its junk now.
Old Sep 22, 2007 | 01:02 AM
What would happen if I were to run the motor like this?
Old Sep 22, 2007 | 01:28 AM
No one knows? Uggggh.
Old Sep 22, 2007 | 01:30 AM
JMBLOWNWS6's Avatar
I personally would not run the block.
Old Sep 22, 2007 | 01:31 AM
Well, my car has been off the road for a while. And my parents want to sell it to a junkyard! If I tell them my block is cracked and I need to buy a new one....I will probably lose the car.
So....what is the worst that will happen if I put the block in the car?
Old Sep 22, 2007 | 01:32 AM
JMBLOWNWS6's Avatar
Why dont you do me a favor and take a pic of where this happened.
Old Sep 22, 2007 | 01:35 AM
I will do it tomorrow. No where that it went into a cylinder wall. Just coolant passage if anything. It is soooo small. I looked at it with a flashlight and couldn't see a crack, so it's tiny...it's literally a pin hole.
My motor is out of the car by the way. I will have a pic tomorrow....
Old Sep 22, 2007 | 01:36 AM
JMBLOWNWS6's Avatar
Either way when you pressurize the cooling system its going to leak. If you want to you can JB weld it!
Old Sep 22, 2007 | 01:43 AM
Well honestly....what can I do.....
Old Sep 22, 2007 | 01:45 AM
JMBLOWNWS6's Avatar
Sucks what happened. I would need to see a pic of the crack. But the odds are against you. Hopefully Im wrong and its nothing and you can keep your car.
Old Sep 22, 2007 | 01:47 AM
Well, I am telling you now....from a picture, you won't see anything. In person I can't even see it! Just curious what to expect...if I do run the motor this way, what will happen?
Old Sep 22, 2007 | 01:49 AM
JMBLOWNWS6's Avatar
It WILL loose coolant and overheat.
Old Sep 22, 2007 | 01:52 AM
I can deal with that. hahah. Ugh, this sucks.....It can't be like tig welded since it's a pin hole?
Old Sep 22, 2007 | 11:05 AM
Lt1Porsche's Avatar
So you have a pin hole that you cannot see, dont know where it is. I would take the block and have is magnafluxed and checked for cracks. If there is a pin hole that is leaking. I would NOT run that motor.
Old Sep 22, 2007 | 11:10 AM
I know what would normally be the right thing to do...but my parents want my car gone already....so I really have no choice.
Old Sep 22, 2007 | 01:54 PM
lmt0705's Avatar
jb weld the area. what have you got to loose? i used it to fix a cracked block on a diesel a few years ago and its still holding
Old Sep 22, 2007 | 02:38 PM
ZZebes's Avatar
JB weld that bitch and pray
Old Sep 22, 2007 | 03:29 PM
Tainted's Avatar
if tis trely as small as you say you could probably have it welded or jb welded
Old Sep 22, 2007 | 03:31 PM
Lt1Porsche's Avatar
yea you can use JB weld just make sure that the area is VERY VERY clean. The cleaner the better chance you have of it holding up.
