MS4 and Yella Terra's...NE Problems??
Hey guys, I noticed while reading a tech write up on ls1howto, it mentioned adding aftermarket rockers to a high lift cam may be dangerous do to the aftermarket rockers increased strength/no flex. Those with the MS4, any problems with aftermarket rockers? namely yella terra's? Thank you
someone correct me if im wrong but i believe thats just if you are using a higher than stock ration on your rockers. Like if you used 1.8RR's then you wouldnt want a high lift cam, but youd be ok with 1.7RR's.
sounds good guys. I'll call Texas Speed just to make sure. My main concern was accourding to the write up on ls1howto for the yella terra rocker install, they warn that the stock rockers flex when using stiff springs, and should see a 20 thousanths or so gain in lift when switching to a better rocker. IIRC the ptv for the ms4 is only 30 thousanths or so, but that figure is probably when using an aftermarket rocker.
