Cam without Stall owners come in
Old Sep 27, 2007 | 02:46 AM
Websy21's Avatar
Originally Posted by dannyz
I have had my fuddle for two years now, w/o any issues at all.
don't know how many bottles of nitrous I have gone thru, but thus far my 'verter is working as good asd the day it was put in.
I also sport 2.73 gears.
I would think that if my fuddle can handle a 125 shot, [ around 100 to the wheels] it should stand up to a cam easy.
Old Sep 27, 2007 | 09:27 AM
SOMe WS6's Avatar
i went with a Vig3200 with my setup and i used to daily drive it with no problems. now that i dont DD it i wish i would have gone bigger around a 4000
Old Sep 27, 2007 | 09:34 AM
bowe1632's Avatar
i spoke to i think it was alan futral and he told me a 3200 works optimally with the F13 on the roads. of course if ur dragging only, u can bump that up quite a bit but that is what ive been told...so am i correct to assume any cam in that low 230/232 range would prolly be pretty tight at 3200? im looking for a quality converter at 3200 for my set up, i think it should work quite nicely.
Old Sep 27, 2007 | 09:56 AM
transamfreak01's Avatar
with a 230/232 cam i would go bigger than a 3200. i would do atleast a 3600. some advice though, do not go small b/c you are afriad of the drivability. like i said b4, i had my yank ss 3600 put in and tuned and dont get me wrong its amazing, but i wish i would have gone with the ss4000.
Old Sep 27, 2007 | 11:25 AM
PREDATOR-Z's Avatar
VIG 3200 will be perfect, it flashes around 35/3600
Old Sep 28, 2007 | 12:18 PM
cals400ex's Avatar
i went with a tr224-112, TSP 2.5 5.3L heads, LS6 intake, and the 01-02 injectors. i run the stock stall with it. a lot were saying i would lose low end. however it has a lot more power, even down low, than the stock setup. i am not sure if it was the cam, heads, intake, etc. yes, it runs a lot better up top too. i was expecting it to be a dog out of the hole from what many told me. that just wasn't the case here. it had quite a bit more power coming out of the hole, even with the stock stall.
Old Oct 1, 2007 | 01:46 PM
SOMe WS6's Avatar
yes, that is about what my VIG flashes to
Old Oct 1, 2007 | 02:17 PM
99Hawk262's Avatar
Very true....I had a Yank ST3500 and now run a SS4000 and there was no difference in city driving between the two. Took the same amount of gas to move out and everything. All the differences were at WOT . My next converter will be a PT4400 .
Old Oct 2, 2007 | 11:28 AM
Reject's Avatar
aaaah i remember my days with the ms4 and stock stall with 2.73's
fun scary times
