Roller rockers, advice
Old Sep 26, 2007 | 10:47 AM
Dragkid1917's Avatar
Default Roller rockers, advice
OK i got a tsp cam, 233/239 .598/.603 112LSA And i was wondering A) how much h/p on average do roller rockers pick up over stock with 1.7 ratio. And B, do you think instead of goin to 1.8 or 1.85:1, i could pull off a simple 1.75:1 change, making the lift .616/.621?
Old Sep 26, 2007 | 11:04 AM
teke184's Avatar
you can't go 1.8 or 1.85 with that cam...ramp rates are too steep.
just swapping the stockers for full roller 1.7 rockers....probably not much....5hp?
the 1.75s should work...or i've heard them working. but even then you'd only pick up maybe 10hp.
Old Sep 26, 2007 | 11:11 AM
if im gunna swap em, 10 hp is fine with me. Better then nothing you know? I just wonder if i gotto change the pushrods for length reasons or what the new tq specs will be.
Old Sep 26, 2007 | 11:41 AM
also do u know the clearence with these heads, i wanna mill .040, and do those rockers, do you think itll clear?
Old Sep 26, 2007 | 02:08 PM
teke184's Avatar
if you keep the same heads as what the stockers are on...than pushrods and torque specs should not change.
with new heads...who knows. best bet is to buy a length checker...why guess.
oh...and what heads are you talking about??
Old Sep 27, 2007 | 11:59 AM
the 241's.....
Old Sep 27, 2007 | 08:19 PM
Krab's Avatar
If your stock rockers aren't taking a dump, I personally wouldn't mess with them. I tried some roller rockers some time ago and they were more trouble than what they're worth (improper tolerences, hex socket needed, having to mount them, properly torque down, etc.).
Old Sep 28, 2007 | 12:11 AM
DONAIMIAN's Avatar
While the heads are off it would be smart to enlarge the pushrod holes. And you will need new pushrods.
Old Sep 28, 2007 | 09:54 AM
i just got brand new ones (pushrods). What do you mean with improper tollerenes and having to mount them?
