shaved heads compression?
i have a 2000 trans am. what is stock compression? i just bought 241 heads and im having them shaved .040". what will my new compression be and what is the cc on these new heads before and after the shaving? whats the cc on the stock 00 heads?
OWN3D BY MY PROF!
.040 / .007 = 5.7142857142857142857142857142857cc.
66.67cc - 5.7142857142857142857142857142857 = 60.955714285714285714285714285715 aproximately = 61cc.
I got right around 11.11:1 with a .052 compressed head gasket and .006 out of the hole. I'm not sure on the head gasket bore diameter, but I used 3.910 which I'm pretty sure is right, but not 100%.
Originally Posted by Bo White
Also keep in mind that when you mill .040" off the head you need .040" shorter pushrods.
Most pushrods are only availible in .025" increments, if its milled less than .025 just run the ones you have. If you mill a head X amount you also move the rocker X amount closer to the cam.
Never thought of the pushrod thing, do you think milling the heads .040 and with a .616/.620 lift will clear? I wanna get some new rockers too, and the pushrods are the 7.4 cromoly's. I dont know how there gunna fit now.... but... about the clearence... anyone?....
The base circle on my cam is 1.450 vs stock 1.550, so its .100 smaller diameter, or .050. Stock PRs are 7.380 vs aftermarket 7.400 for a difference of .020 longer. The mill is .040. Not sure what yoru gasket is, but lets assume its a .045 down from a stock .053 for a difference of .008 tighter.
-.050
+.020
+.040
+.008
This totals out to +.018 over stock length. Hydraulic lifters should be able to absorb this extra length fairly easily, but as you can see, dropping to 7.375 pushrods would bring you closer to stock spec at .007 under.
Personally im running my pushrods at .012 over, and iv very happy with the setup.
