High Compression Motors
Old Jun 4, 2003 | 10:11 AM
ls1290's Avatar
Dumb Ass Vette Moderator
Default High Compression Motors
Do high compression motors require lower timing?
Old Jun 4, 2003 | 10:26 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Default Re: High Compression Motors
I made more power with less timing and more fuel.
I ended up making 475rwhp/ 505rwtq with 12:1 AF and 26 degrees of timing.
I suggest doing what I did. Do a pull with one set of parameters and then change the timing, two degrees up or down, and do this a few times.
I think a big motor needs a fatter AF since it will be under much more load on the track. I think it's a good idea to hit a good number and then fatten up the AF to make it safe.
