Patriot or Trick Flow combo
im thinking of either going with a patriot stage2 h/c package or trick flow stage3 h/c package. whose running either combo? what kind of numbers are you getting?
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Originally Posted by k-mart
Are you comparing Patriot stage 2 heads to TFS heads and their Stage 3 cam?
If so, there's really no comparison if ou can justify the price. TFS all the way.
As stated your looking at different ends of the cost spectrum.
If you have $3500 for the TFS heads and new rockers you'll need then thats the combo for you.
In the end you still need to research the results to justify the money. Is the TFS combo really worth it in power to cost over the Patriot combo. Only you can decide that for yourself.
Originally Posted by Gunnar@Patriot
Keep in mind that we will be having a special soon on our newest cam, ported 243's assembled, Manley pushrods, and oem head bolts for $1395.00 !!
I did a combonation of both. I did patriot heads and trick flow stage 3 cam. Im very happy with my results. However I would have bought the trick flows if I had the extra money. Im happy with my patriots though no complaints here.
