RMS 346 is back in action...DYNO RESULTS!
Old Jun 7, 2003 | 01:28 AM
Smoke_ur_5.0's Avatar
Default RMS 346 is back in action...DYNO RESULTS!
After too much stuff to do and opening a new location at RMS we finally got around to getting the formula back together and dynoed with AWESOME results!
Specs of engine:
RMS stage 2 5.7 heads milled .030 with 987 springs
RMS custom grind...big *** cam.
RMS ported throttle body
RMS tuning
SLP lid
SLP MAF
SLP bellows
LS6 intake
Yella Terra 1.7 rockers
SVO 30# injectors
Dynatech headers
True dual exhaust with Hpipe
RMS Shortblock consisting of:
Diamond pistons 11.75/1 compression (Thanks Chris @Diamond)
Eagle rods
Stock crank
LS6 block bored .005 over
Rollmaster timing chain with torrington bearing
Results were 463rwhp, 418rwtq!!!!!!!!!!!
Yes this was though a MOser 12 bolt and 315 nittos!!!
Can't wait to take this thing to the track Weds!!!
Old Jun 7, 2003 | 02:57 AM
Jason99T/A's Avatar
I can shift faster than you.
Default Re: RMS 346 is back in action...DYNO RESULTS!
Damn Mark, that is awesome with a hydraulic cam and your drivetrain!
Are you using 5.3l heads?
Old Jun 7, 2003 | 06:18 AM
jfm's Avatar
jfm
Kick *** numbers,congrats.What size injectors are you using?
Old Jun 7, 2003 | 06:21 AM
bspz28's Avatar
Nice number man . the car is going to fly
Old Jun 7, 2003 | 07:53 AM
oOoLy's Avatar
WOW!! awesome number
Old Jun 7, 2003 | 08:09 AM
2000SILVERTA's Avatar
Get that beast to the track and see if you can bust a 10 with it.
Old Jun 7, 2003 | 08:35 AM
93Polo's Avatar
Damn those are big #s Please post the graph and some more info.
I just received my rockers thanks guys. Getting close to time to decide on H&C
Old Jun 7, 2003 | 08:51 AM
Phil99vette's Avatar
7 Second Club
OMG those numbers are sick. I hope my 347 cid forged high compression makes similar #s. Can you post a dyno graph?
Phillip
Old Jun 7, 2003 | 08:52 AM
7 Second Club
WOW, looking at your setup, my motor is basically the same combo. Eagle rods, diamond pistons ect. What CC are your combustion chambers and how big of a cam? You on 5.3's or Ls6s?
Phillip
Old Jun 7, 2003 | 09:17 AM
Actually they are only 5.7 heads milled .030 and we used 30# SVO injectors.
We are going to buy a scanner today and hopefully get the graph up today.
and yes we would dyno this on another dynojet to back the numbers!
Old Jun 7, 2003 | 09:30 AM
JayLS1-327's Avatar
WOW that is unbelievable.
Let's see the graph Mark.
Old Jun 7, 2003 | 10:06 AM
Mike K.'s Avatar
Nice numbers
Old Jun 7, 2003 | 10:21 AM
gator's 99TA's Avatar
change that sig mark! awesome results! looks like your custom grind cam not only made great peak horsepower but ALSO made great TORQUE! i bet it feels like a beast! look out, people are gonna be burning up your phone for this can.
Old Jun 7, 2003 | 10:25 AM
Jason99T/A's Avatar
Cool deal, did the porter do any welding in the chambers to reduce the CC or did you get the extra compression through a thinner head gasket, dome piston,etc.? It took my solid roller setup 55-56cc chambers to get around that compression (11.5-11.6:1).
I can't wait to see track time!! 10s will be definitely possible!
Jason
Old Jun 7, 2003 | 10:36 AM
XLR8NSS's Avatar
Adkoonerstrator
Awesome results!!
Now quit messing with the car and throw that sucker in the TRUCK.
John
Old Jun 7, 2003 | 12:05 PM
We used a dome piston...here's a pic of the motor and the pistons.
http://64.49.232.188/images/products/rms/RMS%20004.jpg
http://64.49.232.188/images/products/rms/RMS%20005.jpg
http://64.49.232.188/images/products/rms/RMS%20007.jpg
http://64.49.232.188/images/products/rms/RMS%20008.jpg
http://64.49.232.188/images/products/rms/RMS%20009.jpg
http://64.49.232.188/images/products/rms/RMS%20006.jpg
XLR8NSS...LOL!!
Old Jun 7, 2003 | 12:14 PM
JF WS6's Avatar
Yeah Mark, those numbers are sick...... I wonder what you'd get with some stage II ported LS6 heads on there milled the same...
Old Jun 7, 2003 | 12:22 PM
383ss's Avatar
that is bad *** mark!!!! great to finally see a local guy put up those numbers! I'll have to swing by and hear it lope
Old Jun 7, 2003 | 12:23 PM
Ragtop 99's Avatar
Way to go mark!
BTW, the shop looks tooooo clean. :p
Old Jun 7, 2003 | 12:34 PM
Jason99T/A's Avatar
I kinda figured you were using dome pistons. Chris@Diamond is doing a set for my solid roller now, but my dome is going to be a little larger. lol
Again, nice job Mark!
