what is the different between this cams ?
Old Oct 7, 2007 | 08:35 PM
camaro_best's Avatar
Default what is the different between this cams ?
1- 228/232 .588/.592 110LSA +4
2- 228/232 .588/.595 110LSA +4
i know 3 lift more on Exhaust,,
but my Q about the Dyno number hp and TQ?
Old Oct 7, 2007 | 08:40 PM
1_bad_TA's Avatar
If there is a difference, I think it will be VERY small.
Quick question, were you being serious?
Old Oct 7, 2007 | 08:44 PM
JScamaro's Avatar
Those are the exact same cams. The xer 232 lobe has .595 lift and the first cam with .592 is incorrect unless it was read on a cam doctor where the duration and lift can vary slightly.
Old Oct 7, 2007 | 09:06 PM
axles of evil's Avatar
where did you find these cams ? i was going to get one very similar custom ground. maybe i can pick up an off the shelf and save some green
Old Oct 8, 2007 | 08:12 AM
custom cams from Patrick G
speedInc.com grind it take only 3-4 days
my cam now
see my # on 1998 LS1 stock heads a4
video idle :http://www.youtube.com/watch?v=yzF2ynwYrps
video 2 idle :http://www.youtube.com/watch?v=ktsXS9ZYo5Q
