59cc heads what is the compression ratio
Old Oct 8, 2007 | 07:35 PM
skeeters65's Avatar
Default 59cc heads what is the compression ratio
On a 2002 LS1 F-Body
Thanks
64cc is stock and is 10.4 to 1 right??
Old Oct 8, 2007 | 10:03 PM
JScamaro's Avatar
Depends on what size your head gasket is and what cam you are running (advance).
Old Oct 8, 2007 | 10:33 PM
hammertime's Avatar
Stock LS1 heads are 66.67cc nominal chamber volume = 10.1:1
LS6 heads are 64cc nominal chamber volume = 10.42:1
59cc heads with stock .053 gaskets = 11.09:1
59cc heads with .040 gaskets = 11.47:1
All compression ratios calculated from the published 10.1:1 LS1 ratio, using the difference between volumes.
Also, camshaft selection and degreeing will determine your dynamic compression, but the static compression is fixed by the volumes at TDC and BDC.
