ok, scrutinize this combo...
Old Jun 8, 2003 | 01:25 PM
BYBYC5's Avatar
*Bad Trader*
Default ok, scrutinize this combo...
i trashed my 408 so now im geting the TSP 396 offset, but while in gatering fundage, in gonna run this..
stock rebuilt bottom end
S1 5.3 heads milled .015 2.00/1.56 stainless valves (11.1CR)
hotcam (ya i know but its all i have right now
3.73, and a MW3600 verter.
longtubes with true dual(X-pipe)
ls6 intake (its 2001)
85mm MAF
and programming from RMS....
and a 150 shot.....
ok let the flamming begin, PROS<CONS, whatev, its a STREET CAR not a Track or Dyno *****.
Old Jun 8, 2003 | 01:31 PM
SNAXS's Avatar
Default Re: ok, scrutinize this combo...
I say it will go low 11's out of the hole. How did u trash the 408 if u dont mind me asking!
Old Jun 8, 2003 | 01:32 PM
BYBYC5's Avatar
*Bad Trader*
pistons and valves had a disagreement, they both lost.
Old Jun 8, 2003 | 02:03 PM
2001CamaroGuy's Avatar
Over all, it looks like a pretty cool engine (wish I could afford that...). You said you have a "stock rebuilt bottom end." Does that mean stock pistons? If so, I would say spend the money and go forged. The factory crank is plenty strong. The rods are good IF you replace the bolts with a set from ARP. Also, use studs where ever you can. They are stronger and easier to work with.
The hot cam is REALLY small for that much engine. I don't know if you are interested, but I have a 234/230 on a 112LSA that I had ground for my engine never used.
Old Jun 8, 2003 | 04:16 PM
Iv_z28's Avatar
The engine in question isn't 396, but , I believe, 346 stock block with S1 heads , hotcam and LT's
Old Jun 8, 2003 | 05:05 PM
TSP 396 offset
what does he mean by this then.......I thought he was talking about an offset ground crank to make 396 CIs???
Old Jun 8, 2003 | 05:32 PM
BYBYC5's Avatar
*Bad Trader*
yes im buying the TSP 396 offset kit,BUT UNTIL THEN im running the above combo...so..
ttt
anyone eles wanna comment on how it will perform?
Old Jun 8, 2003 | 09:42 PM
Terry Burger's Avatar
It will be slower than my car. That's all that matters....
Old Jun 8, 2003 | 10:01 PM
NA$TY-TA's Avatar
than your honda?
Old Jun 8, 2003 | 10:02 PM
BYBYC5's Avatar
*Bad Trader*
honda, really? dam terry thought you were better than that. battle of the boltons has begun lol
Old Jun 8, 2003 | 10:05 PM
Vents's Avatar
boltons? really? i thought you both were better than that...
Old Jun 8, 2003 | 10:08 PM
ttt
OHHHHH....ok....now I get it...my bad....
Old Jun 8, 2003 | 11:30 PM
TApimp's Avatar
i say,
hell yeah!!
lol
