Cam recommendation
Old Jun 8, 2003 | 07:27 PM
Dean LS1's Avatar
Default Cam recommendation
Hi,
Im from Australia and have been browsing this formum for a while and just signed up. You guys are getting some great times with your setups. I plan to go a H/C setup now that I have done all the bolt-on mods and tuning. Now I need some recommendations on what size cam to run. I have an LS1/LS6 intake with built trans and toughend stock stall converter and 3.46 gears. I plan to go stage 1 heads (stock valve size, ported), double valve springs, hardend push rods, arp rod bolts and head studs - what size cam for a daily driver with some occasional track work and circuit racing (tuning is ok)? Also what RPM can you spin to safely with above setup?
Old Jun 8, 2003 | 11:40 PM
someday's Avatar
Default Re: Cam recommendation
what do u mean by "toughened stock stall converter"??? u'll need at least a 3000-3500 flash stall converter to get the most out of it... u won't need double valve springs on a stage 1... jpr makes some good stage 1 heads, he uses LS6 springs and they work great with lower lift cams, comp has a 224/228-.534/.537-112, that would make a good combo... it would need tuning, and would probably peak around 6300, with a redline of 6600...
Old Jun 9, 2003 | 12:46 AM
Dean LS1's Avatar
Had a few stronger bits installed in the standard converter when I got my trans done - same stall speed (1600 I think).
Old Jun 9, 2003 | 12:50 AM
TApimp's Avatar
i heard in australia yalls motors turn in reverse rotation???
j/k welcome to the board. i would do something like a 220 or 224 duration, or maybe even a z06 cam
Old Jun 10, 2003 | 11:01 PM
Dean LS1's Avatar
I have decided to go the stall convertor (prob 2500-3000 rpm). What size cam can you go with good drivability for a daily driver, some occasional track work and circuit racing (reason for going for a lower rpm stall)?
Old Jun 10, 2003 | 11:06 PM
Cal's Avatar
Cal
What is good driveability to one person is a total asspain to another.
