Best sleeper cam??
not a sleeper cam anymore mr. garcia.... :p
If your serious about a sleeper cam, call each shop and talk to them sepratley over the phone about this
What about the Thunder Racing "Old Man Cam"?
It's billed as a sleeper cam with a stock idle.
http://www.thunderracing.com/index.c...yid=1114#T1159
215/220 .600/.523 115
I have a 224/224 0.581/0.581 114LSA in my corvette, with LT headers and the stock exhaust. The exhaust note sounds the same as stock, and it idles like stock (only bumped idle speed 50rpm). It's only louder at WOT/higher rpms. There's more valvetrain noise, I don't know how noticable it is from outside the car. I hear Yella Terra roller rockers would eliminate most of the extra valvetrain noise.
If you keep your mufflers stock, you can run a fairly big cam and it'll sound stock.
Originally posted by Cal:
Well, I finally got that cam installed this weekend (Comp Cams 222/224 .566/.567 115 LSA, XE lobes), along with TEA Stage 1.5 heads (with Comp 987 springs & titanium retainers), an ASP underdrive pulley, and an overdrive alternator pulley. I'm leaving the stock manifolds on, but will be replacing the cats with Mufflex cat-bypass pipes next week.
I haven't dyno'd it yet, and I won't be taking it to the track until next week, but I will say this for certain: If this isn't the sleepiest sleeper cam around, I don't know what is. No lope whatsoever, and I got rid of the last bit of cam surge with some idle tuning (~875 RPM idle in Park) and changing the throttle body blade hole from 11/32" to 13/32". My wife couldn't tell the difference in the car's sound when I started it for her. It sounds a little deeper, but that's it. Power is better in the midrange, and really comes alive up top. I'll post times when I get 'em. I can post a sound clip if anybody wants to hear it. (But I'm tellin' ya, it just sounds like a stock LS1.)
Hey Killer, I was going to get that cam but I wound up getting a TR224 since it was on a GP for a good price. I'll be interested to hear how it works out for you. BTW, a don't think it will be much of a sleeper cam, even on a 115 LSA. :p
Killer, thanks for the report on that 222/224; I guess the way you got it on a 115 smoothed it out along with your PCM tuning (high idle helps for sure.) If you dump your cats, it might become more noticeable, though; cats make a huge difference in exhaust sound. Hey, if it fooled your wife, that's worth something! I'm hoping to do the same with a TR224 114; if my wife knew how much I'm spending on this cam swap, she'd blow a gasket!
I'm going to install it while she is out of town, and just tell her I did the LS6 pcv upgrade!
