Worst Heads
Old Oct 17, 2007 | 12:46 PM
xBROKEx's Avatar
Originally Posted by SEBLS1
No tune. Just rough Dyno Numbers OH & BIG THING I FORGOT. These are 243 heads OOPS
well yeah hes gonna lose power with no tune and that big of a difference in A/F ratio
Old Oct 17, 2007 | 12:52 PM
SEB's Avatar
SEB
So 370 RWHP at 5500 RPM with 243 would be on target for no tune you think?
We are going to install the 241s & see what happens. I was thinking that the car should have done pretty close to 400 RWHP with no tune with Ported 243 LS6 heads.
Does a Tune really pick up 50 RWHP?
Old Oct 17, 2007 | 12:59 PM
xBROKEx's Avatar
yeah, think about it, you are adding a huge amount more air to the engine without making any change to the fuel mapping. Im suprised he isnt throwing codes and running ***** rich. I would get it tuned before you went swapping out any heads.
Old Oct 17, 2007 | 01:26 PM
ONEBADWS6's Avatar
So you go from stock heads and intake to a ported 243 head and 90mm setup and don't think you need a tune. Your shitting me right. Slap your friend for all of us.
Old Oct 17, 2007 | 01:28 PM
xBROKEx's Avatar
kinda shady dyno to, with the only revving to 5500, since stock redline is higher than that
Old Oct 17, 2007 | 01:43 PM
SEB's Avatar
SEB
I just don't understand why the base numbers where so low. They never really played with the tune. They took the car up to 5500 RPMS & shut it down.
So had they taken the Vinticator cam up to the intended 6500 RPMS & tuned the car. 420 RWHP was in pretty good reach & we are overreacting at this point I take it.
ONEBADWS6's Avatar
yeah spin it to 7k
Old Oct 17, 2007 | 01:44 PM
ONEBADWS6's Avatar
Well since a 90mm setup changes a tune quite a bit, add in the heads and yes alot is on the table. Tune it and run it up to 7k. Then get back to us.
Old Oct 17, 2007 | 01:47 PM
SEB's Avatar
SEB
Considering the Valve Springs are new. Run the car to 7Grand on the 1-2 shift & 2-3 shift. Just worried if the springs will take those RPMS
Old Oct 17, 2007 | 02:10 PM
ONEBADWS6's Avatar
????????????? Why would you run it up to rpms between shifts? You dyno in 3rd gear for a auto and 4th for a M6. If the springs are matched to the cam they can take it just fine.
Old Oct 17, 2007 | 03:58 PM
Asmodeus's Avatar
So.. if I put in a new cam, new intake, and new heads..
I'm going to make less power without tuning for the new combo AND only spinning the motor 1000 rpm's under peak power?
Your shitting me right?
  #32
xBROKEx's Avatar
id do lifters to before i rev that high
Old Oct 17, 2007 | 11:49 PM
  #33
Omega Doom's Avatar
doesn't make sense for the tuner to only go to 5500rpm and shut it down unless it had maybe some valve float issues or something else maybe? something doesn't seem right?
Old Oct 17, 2007 | 11:57 PM
  #34
99blancoSS's Avatar
Yes the 853's are the worst of the bunch. This is old basic info
Old Oct 18, 2007 | 02:46 PM
  #35
Omega Doom's Avatar
I would be pissed if a shop pulled the same crap on me! damn how many days does it take to do a set of heads? especially if they need it out of the way?
Old Oct 18, 2007 | 04:58 PM
  #36
WOTFMAN's Avatar
Seb this aint your buddies car man...Why lie. Its your OWN car you are asking about!
Old Oct 18, 2007 | 05:06 PM
  #37
BOWTIE's Avatar
Well I had some suggestions until i got to pg 3... at this point, why bother.
Old Oct 18, 2007 | 09:23 PM
  #38
xBROKEx's Avatar
Old Oct 18, 2007 | 10:14 PM
  #39
COOKIE MONSTER's Avatar
Cam and Heads go hand in hand
Old Oct 19, 2007 | 01:34 AM
  #40
WS6Drop's Avatar
There is a head sticky. The 853's and 241's flow the same. The 243's are better. It really doesnt matter after they are ported anyway. There is nothing wrong with a set of ported 241 or 853 heads done correctly. There are a lot of good ported LS1 castings being used on many cars that make great power.
