Block prep
Old Oct 17, 2007 | 11:05 PM
blueeyeddevil141's Avatar
Default Block prep
Just got my block and parts back from the machine shop. Is it safe to hit the block with a hose and some soap?
Old Oct 17, 2007 | 11:11 PM
fuseone's Avatar
what to wash out the cylinder walls yes its fine then if thats what you wanna do.
Old Oct 17, 2007 | 11:15 PM
Just the whole block, cylinder walls, lifter bores, oil passages. Then I will run a brush through the lifter bores and oil gallerys with some mineral spirits. Then before final assembly wipe down the cylinders with some acrylic laquer.
Old Oct 19, 2007 | 07:30 PM
JPH's Avatar
JPH
take it to the local carwash and powerwash that thing crystal clean. then blow all the water out of it, and re oil metal surfaces so they don't rust.
Old Oct 19, 2007 | 09:15 PM
8a8mfh's Avatar
acrylic laquer is paint dumbass. Thanks to your other post, you get this remark.
Old Oct 19, 2007 | 09:59 PM
Tom@SpeedInc's Avatar
make sure you remove all the water/soap, by compressed air?
spray the block down with WD40 after dry.
Old Oct 19, 2007 | 10:38 PM
Actually, it's not...I have a can of it, 100% virgin acrylic laquer thinner is what MANY engine builders use to clean down cylinder walls.
Old Oct 19, 2007 | 11:29 PM
8a8mfh's Avatar
And what is acrylic laquer thinner used to thin?
The acrylic laquer (paint). That you're going to put on your cylinders
Most people I know call it lacquer thinner.
Old Oct 19, 2007 | 11:37 PM
N4cer's Avatar
Yeah I've heard people call it lacquer as well. They're wrong. It's lacquer thinner.
Old Oct 20, 2007 | 01:34 AM
Just to clerify, I am not painting my cylinders haha.
Old Oct 20, 2007 | 09:56 AM
8a8mfh's Avatar
LOL
Old Oct 22, 2007 | 11:56 PM
JRracing's Avatar
That's funny ****... I'm a painter. LOL.
Old Oct 23, 2007 | 12:27 PM
MeentSS02's Avatar
Kleeborp the Moderator™
Why not? I'd paint mine to match my car...it should make it much faster. Plus, it gives the rings something fun to do while they are flopping around in there.
Old Oct 23, 2007 | 09:05 PM
santiago's Avatar
i painted my crank, pistons and rods before install finished everything off inside and out with 9 clearcoats
Old Oct 23, 2007 | 10:19 PM
3.4camaro's Avatar
It's all in the details. Now THAT'S how you win car shows.
Old Oct 23, 2007 | 10:31 PM
Backed, I paint my rotors and tires too.
Old Oct 24, 2007 | 12:51 AM
Grimes's Avatar
Immediately after you wash it down, I'd hit up all the machined surfaces with auto trans fluid or wd40 to prevent rust
