MS4 cam
Old Oct 18, 2007 | 02:30 AM
Domexitium's Avatar
Default MS4 cam
Will a MS4 cam fit with out fly cutting the pistons?
Old Oct 18, 2007 | 02:35 AM
venom ws7's Avatar
with stock heads YES.
Old Oct 18, 2007 | 02:50 AM
BES Stroked Nova's Avatar
i will agree, with stock heads, it works great! i am another happy one with the MS4... but watch out, you will push your stock fuel system beyond max... and that will hold you back from making the full power the cam can make. at least thats my problem right now.
Old Oct 18, 2007 | 01:43 PM
Domexitium's Avatar
well, i have a 6.0Litter head I don't know how big the gasket is though. The only upgrade to my Fuel system is the pump (Wahlbro 255lph In Tank Fuel Pump) do you mean upgrade the injectors? BTW the cam that is in there right now is a TSP 231/237. I'm not sure of the lift or LSA
Old Oct 18, 2007 | 02:12 PM
ls1_doc's Avatar
Yeah i am a little interseted as to what part of the fuel system in being maxed out.
Old Oct 19, 2007 | 10:45 AM
98mysticZ's Avatar
the injectors mabye.... but when i did mine i upgraded the fuel pump and injectors... walbro intank and 42lb svo's cause i was going to spray it.... but UPGRADE THE ROD BOLTS or you will develop the factory optioned high performance rod knock
Old Oct 19, 2007 | 01:34 PM
yea, i ment to say injectors... working 12 hour days, make your mind go crazy!
anyways, i am reving the **** out of mine, but i got those damned 12 point headed rod bolts
I got the high end of my tune back down some till i get my fuel system done here shortly, and it still ended up running the times in my sig... great job TSP! my F-11 would never have ran that fast! small cam nut swingers go home!
Charlie
Old Oct 19, 2007 | 01:39 PM
fatdave's Avatar
I have the MS4 and I am just waiting on my headers, intake and machine work on heads( valve angle job and porting). I am upgrading the intake pump and going with 36lb injectors, with bigger rails. You all think my fuel system will be ok?
Old Oct 19, 2007 | 02:19 PM
well my injectors were the first to show, 110% duty cycle... but i'd say the stock pump wont be far behind...
