Ring gap direction?
Old Oct 19, 2007 | 08:15 PM
N4cer's Avatar
Default Ring gap direction?
When installing rings on a piston, what direction should the ring gaps face?
Top ring?
2nd ring?
1st oil rail?
2nd oil rail?
Just wondered. It might not matter, but I'm building an engine for the first time and want to leave no stone unturned. They say it's the details that make all the difference.
Old Oct 19, 2007 | 09:38 PM
ChiTownHustler's Avatar
Here is how I do them:
With the piston installed in the bore place the top ring gap up toward the lifters
Then install the 2nd gap 180° from the top ring
Then install the oil expander the same as the top ring gap, then the top and bottom oil rings 135° offset from each side
Old Oct 19, 2007 | 09:57 PM
N4cer's Avatar
I gotcha on the top and bottom gaps.
On my Hellfire rings, it says to put the expander ring so that it butts above the end of the pin. Sound okay?
Thanks for the help.
Old Feb 27, 2008 | 10:55 PM
I really don't think it matter much. Everyone has their own way of doing things. Both should work fine
Old Feb 28, 2008 | 10:07 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
Just make sure the top and middle rings are 180* out
