YELLA TERRA INSTALL PROBLEM (NOISE)
Just my 2 cents.
...go back and check each one carefully ..hope you did not bend any pushrods, valves, or other expensive stuff...
As for running the engine for only a few seconds, the engine will be REALLY NOISY for the first few seconds of starting up the car after you fire it up. The lifters have to re-pump up. This is very common after releiving the preload on the lifters (ie, removing the rockers) and rebolting them on.
If you start it and it stays noisy after 5-10 seconds, then there is an issue. You should not be having slack in the valvetrain once the lifters get filled with oil, and 0 lash should be pretty easy to spot so I'm not sure what exactly the issue is with your car.
Run it for more than a few seconds and make sure you have oil pressure.
Jmx: I agree. Unnecessary to check unless something is screwed up. Good job on the writeup, I had a copy handy when I did my install.
When we did it some of the rocker pairs bound up and the two rocker bolts did not go down all the way. This was caused by the set getting slightly cocked to one side.
After we cycled the engine by hand a few times the sets semed to straighten out and seat better against the head. We then re-tightened them and some were VERY loose, others were seated correctly before the cycle.
Did anyone else have a similar experience?
As far as the noise - mine were ticking like a bitch and I was freaking out - I called Mark @ Raging MS and he said it was common until the lifters "pumped" up again. We verified no rubs then held the revs to about 2K for 30 seconds. Not a peep after that.
I also sprayed a 1/2 bottle of silicone on the valve stems, rockers, valve seals, etc. (I copied John Force on that one)
My start-up was NOT noticably different from every other time I started the motor!
