whats all needed to change lifters?
Old Oct 25, 2007 | 04:06 PM
Daryn's Avatar
Formerly darynC-10/23/10
Default whats all needed to change lifters?
ive ben hearing a ugly knock in my motor on the passenger side ...its not the rockers or pushrods. so im goin with the lifters .
ill be changing my timing set too since its still stock
any other ideas?... should i need new head bolts since im takin my heads off?
Old Oct 25, 2007 | 04:15 PM
Asmodeus's Avatar
Yes, you need new bolts and gaskets.
Old Oct 25, 2007 | 04:20 PM
BIG_MIKE2005's Avatar
^^ Yep. Just get some new GM head bolts or ARP head bolts & new head gaskets.
I'd replace them with LS7 lifters since they are very affordable & a upgrade over stock. Just remember to soak them first. And if your gonna change you timing set, you'll at least need a new crank pulley bolt too. You might also check your water pump gaskets, crank seal(in timing cover) & timing cover gasket.
Old Oct 25, 2007 | 04:33 PM
Ws6man2000's Avatar
From: Ft lewis,Ft sill and thats all i hope.Katy texas
get arp head bolts, do not get stock you will waste your time and money
Old Oct 25, 2007 | 04:36 PM
Daryn's Avatar
thanks for the replys guys!
Old Oct 25, 2007 | 05:06 PM
ExceSSive's Avatar
Wink
They are right about all that. I just finished pulling my motor apart for a broken piston.
You need:
  • head gaskets (optional cometic for better compression but expensive)
  • head bolts (ARP are much better and if you ever plan on swapping heads do it now or use studs)
  • front cover seal
  • front cover gasket
  • waterpump gaskets 2 of them
  • crank puller
  • new crank bolt
  • RTV for oil pan
  • anti-freeze and distilled water for radiator
  • fresh oil
  • exhaust manifold gaskets
  • extra tranny fluid if it is an auto
You are going to have to drop the oil pan a little to get the timing chain out there is a 10mm bolt that holds the oil pick up on and you can not get to it without dropping the pan a little. I loosened all the bolts in the pan and the used a screwdriver to make some room. That is all I can think of off the top of my head. Good luck.
P.S.
Might as well throw in a new cam since you are in that far.
Old Oct 25, 2007 | 05:08 PM
3rdgentug's Avatar
^^^ what he said
Old Oct 25, 2007 | 05:17 PM
Ws6man2000's Avatar
you shouldnt have to drop the pan to get the chain out, i pulled mine no prob
Old Oct 25, 2007 | 05:32 PM
Traitor LS1's Avatar
I heard you can get the lifters out without taking the heads off by taking the valley cover of also but its a bit trickier pulling them out
Old Oct 25, 2007 | 10:16 PM
Herper84's Avatar
I'm having to pull my heads to replace my collapsed lifter too. I wanted to just go back with stock heads but realized it was a b!tch to pull the heads. My best suggestion is to put on a new set of heads instead of the stock ones. If you need some graphite head gaskets or some GM head bolts (I went with ARP) send me a PM. Good luck.
Old Oct 25, 2007 | 11:47 PM
massls1guy's Avatar
How did you get the oil pump pickup bolt off with the pan bolted up? I thought that was difficult with the pan dropped.
Old Oct 25, 2007 | 11:48 PM
massls1guy's Avatar
wrong.
Old Oct 26, 2007 | 06:39 AM
There is no way to get the lifters out of a stock LS1 block without removing the heads. Thats a fact.
Old Oct 29, 2007 | 06:34 PM
ExceSSive's Avatar
What he said. I just pulled my oil pump and I could not get a wrench in there without dropping the pan 1/2 inch. I tried for an hour before I broke down and did it.
