car is overheating???????????????????????
Old Oct 29, 2007 | 03:19 PM
fbodymaniac's Avatar
Default car is overheating???????????????????????
What's up everyone I'm having a huger problem out of my 99 z28 and hoping someone can help me out. My problem is that I cant even go cruising in the damn thing without it overheating. The temp is starting to go up into the range where I have to pull over and let the car cool down. I have a new thermo, radiator, and a new water pump. What else can I change to be able to drive my car again. Any suggestions would be appreciated.
Old Oct 29, 2007 | 03:57 PM
PewterZ28's Avatar
Does it overheat just when you are at cruising speeds or is it overheating at idle also? When did the problem start? Is anything even remotely close to blocking your radiator?
Old Oct 29, 2007 | 03:58 PM
Soul TKR's Avatar
what's your coolant look like? low? gunked up?
got any aftermarket heads?... the reason I ask is i saw from another thread a guy had aftermarket heads where the coolant passages were sooooo small that it made his overheat as well...
Old Oct 29, 2007 | 06:40 PM
bowe1632's Avatar
pewter didnt u have an overheating issue once or am i mistaken? how did that turn out? if im thinking of the right dude..what happened?
Old Oct 30, 2007 | 09:27 AM
it usually only overheats while driving. nothing that i can see is blocking my radiator, and I have stock heads. i,m gonna go outside and let it run at idle for awhile to see if it will overheat. my coolant level is right where its supposed to be. im getting ready to take my motor out for a rebuild this winter. i just want to get this overheating problem corrected first.
Old Oct 30, 2007 | 11:05 AM
99blancoSS's Avatar
Make sure the fans are coming on
Old Oct 30, 2007 | 12:05 PM
ArcticZ28's Avatar
Check.
You could easily have a blown fuse or two and the fans aren't coming on. That would be easy to check. If you've put a new waterpump/radiator in, chances are you could have air pockets in there, or the waterpump could not be working, or the radiator has a blockage...
Did you buy all of these things to fix the overheating, or were these done prior to, and could be causing, this problem?
Old Oct 30, 2007 | 02:31 PM
crainholio's Avatar
Are your fans working??????????????????????????????????????????? ?????????????????????????????????????????????????? ?????????????????????????????????????????????????? ?????????????????????????????????????????????????? ?????????????????????????????????????????????????? ?????????????????????????? you seem to like a lot of question marks
Old Oct 30, 2007 | 03:09 PM
TheLS1Kid's Avatar
After the car runs and cools down, open the radiator and check the coolant level.
Did you put the thermostat in backwards?
Old Oct 30, 2007 | 03:11 PM
crainholio's Avatar
How exactly does one accomplish that in an LS1, where the 'stat is part of the neck housing?
Old Oct 30, 2007 | 04:04 PM
TheLS1Kid's Avatar
^Very good point.
I'm at work and have too much other **** on my mind.
I was just thinking overheating+thermostat=possible backward.
I was wrong.
Old Oct 30, 2007 | 05:39 PM
new thermo also, fans are working fine i here them when i turn the car off. doesnt take the car long to cool down either only a couple of minutes. it is overheating at idle also. im thinking maybe i have a blown head gasket. but im no an expert.
Old Oct 30, 2007 | 05:43 PM
TheLS1Kid's Avatar
Thats why I was asking if you were loosing coolant.
If you had a blown head gasket you would be loosing coolant.
Does the car smoke at all?
Old Oct 31, 2007 | 03:57 PM
i noticed a little smoke under the hood but thats about it. nothing coming from exhaust. check engine light is on so i took it to the shop and the guy told a coolant sensor is out but im thinking that cant be it.
