crane cams dual springs
so, according to you, the factory locator for a single spring will be able to locate the inner spring of a crane dual spring.
then why is it that vinci sells the spring locator for the dual springs when they sell it as a kit. retainers, springs, and seat locators? these locators are alot thinner in the middle to locate the inner spring.
![](http://vincihighperformance.com/vinci/products/engine/LS1DUALSPRINGSRETINSERTS.jpg)
sorry mrr23, you are right. there is a misconception in cranes catalog about this. the factory '98-02 ls1 locators will only locate the outer spring, not inner spring. u must use $144460-16 locators and gm seals to make there set up work correctly. sorry for inconvience everyone.
If you only have the springs in hand, and plan to replace your current stock setup (GM beehives), you need seats and retainers at a minimum. You should also replace the seals since they require removal to get the retainers in place. I would also pick up a set of shims so you can get the required seat pressure on the valve springs.
yeah, you do unfortunately. heres a list of what u need man.
1. crane locators #144460-16
2. gm intake valve seals #12457652
3. gm exhaust valve seals #12533856
4. valve spring shims #4753 (comp cams) needed for proper install height.
sorry for the misleading info, i'm not here to do that trust me. mrr23 looks to be doing some more investigating also on this deal.
i just got the springs and retainers
so i need
do i need new locks or can i reuse the old ones
so i need
