Pennzoil Platinum oil analysis results
Old 09-30-2008, 05:25 PM
antonio84's Avatar
I have been using RP for 5 years now, 3 years on the lt1 that i had and now 2 years on my ls1 and never had a problem.
Old 09-30-2008, 08:42 PM
Mike94ZLT1's Avatar
I'm a Redline Synthetic kind of guy, I wonder how the GC would compare to it?
Old 09-30-2008, 09:16 PM
Bigchickenhawk's Avatar
Had RP 10w30 in about 10 different cars, never had any problems in both NA and turbo/sc apps. Currently running 10w30 in a 98 ls1, lid exhaust t56 334 rwhp...somethings working right.
Old 09-30-2008, 09:29 PM
DeepV's Avatar
I've had great luck with pennzoil platinum, ran it in my mr2, used to run mobil one. I currently have mobil 1 in my z but only because it was on sale, come next oil change its gonna be pennz. Mobil just seems to run too thin for what it is.
Old 09-30-2008, 11:06 PM
bigsticksupra's Avatar
i ran Royal Purple ONCE in my Supra and that is when the stock twins blew up. Needless to say, i never used their engine oil after that. I use Amsoil 5w30 in my Camaro.
Old 10-02-2008, 05:16 AM
Patman's Avatar
Originally Posted by CraZee ZO6
awesome results was looking foward to it. I am going to try penzoil plat next oil change..
Patman where would you rate REGULAR CASTOL SYNTEC in comparision to this and GERMAN CASTROL
thanks bud
Regular Castrol Syntec is a pretty good oil too, but it's definitely not at the same level as the German stuff or Pennzoil Platinum. It has shown some good oil analysis results in a lot of different cars.
Old 10-02-2008, 05:18 AM
Patman's Avatar
Originally Posted by black01_WS6
patman- what is a good oil to use with N20? will the pennzoil work, just change more frequently?
It would probably work out well there too, but in a case like that I'd definitely recommend getting an oil analysis done to make sure you've chosen the right oil change interval.
Old 10-02-2008, 11:23 AM
TORCHD 02 TA's Avatar
I was thinking of switching from M1 Syn 5W30 to PP 5W30.... Would that be better? B/C i hear that M1 thins out fast?
Old 10-02-2008, 11:28 AM
DeepV's Avatar
I think it would be, but that just may be me.
Old 10-02-2008, 11:42 AM
well lately i have been hearing good things about PP... so i was thinking of making the switch
Old 10-02-2008, 01:12 PM
Moderator
jimmyblue's Avatar
I quit using Pennzoil years ago because I found a coat
of wax all over the inside of my SBC motor on rebuild.
I figured it was the paraffin base. Is the Platinum a
synthetic, non-paraffinic oil?
Patman, do you maintain a compendium of test results
and maybe a top-10 list based upon, anywhere?
Old 10-02-2008, 01:16 PM
  #32
explain your wax issue you had? Did you have an oil leak?
Old 10-02-2008, 01:20 PM
  #33
Originally Posted by Evans752
I have never ran anything in my car but Mobil 1 and had good results with but I recently switched to the Pennzoil Platinum and it seems to have quiet down the motor (valves noisey) and freed up the motor a hair (reving) and I have always ran regular Pennzoil in all my cars and trucks for over 15yr now with GREAT RESULTS and I am Pleased with the Pennzoil Platinum and plan on sticking with it.
I too have ran syn M1 5W30 since the day i got my car. When i got my cam in back in 2006 my valve train was noisey. Now that i am going to switch to PP i hope my valve train will quiet down some...
Old 10-02-2008, 01:42 PM
  #34
Moderator
jimmyblue's Avatar
I ran nothing but Pennzoil for years in my van w/ SBC350.
It didn't use oil particularly. I lost a rocker stud and took
the time to do a freshen-up, when I got into the valley
I found 1/16"-1/8" of black "wax" coating everything.
I could scrape it off with my thumbnail, that kind of a
consistency. Van had a functional PCV system but no
other emissions controls on it, a '77 3/4 ton from Canada.
I had done a full rebuild when I bought it and the block
was hot-tank clean to start.
I had never, and haven't since seen that kind of thing.
I went to using "Texas" type oils after that and have not
had that kind of deposit. Dunno if it actually matters,
but it wasn't something I would have put on purpose.
Old 10-02-2008, 06:44 PM
  #35
Patman's Avatar
M1 is pretty good at holding it's viscosity, it just doesn't show as low engine wear as PP does.
Old 10-02-2008, 06:48 PM
  #36
Patman's Avatar
I don't really keep a list like that, I just keep an eye on the oil analysis results that I see on www.bobistheoilguy.com to see how certain oils perform in different engines. Pennzoil Platinum consistently performs very well. Even the regular non synthetic Pennzoil has shown very good results for a lot of people too, I haven't heard of anyone finding any kind of waxy buildup inside their engines.
Platinum doesn't use a 100% synthetic base oil, they do use a group 3 hydrocracked base. However, it's Shell's XHVI base oil which is the best group 3 available, it's performance is right on par with pure synthetic base oils.
Old 10-03-2008, 05:20 PM
  #37
chriswtx's Avatar
That was pretty common with the older non-synthetic oils in old SBCs. The new Pennzoil Platinum is totally different and on par if not better than M1 now...
Old 10-03-2008, 08:00 PM
  #38
BAKED's Avatar
I've always ran regular Penn. and I've never had the wax issue. Now, I've torn apart a few Valvoline motors and seen some NASTY stuff. Like for instance, a solid mold of wax when I pulled the valve covers off! Not just on one engine either, I've seen quite a lot of them. I wouldn't lube my bicycle chain with that stuff.
Quick Reply: Pennzoil Platinum oil analysis results
