5.3vs. LS6 Heads
Planned mods 98 T.A.:
Yank SS3600 stall
L6 Intake
LT's with catted Y (gotta pass visual inspection)
Hooker 3inch catback w/ aeroflow muffler
necessary oil pump/timing chain upgrades
Torquer V2 or V3 cam
I am getting conflicting advice on the heads. I had decided on PRC stage 2.5 heads because of the compression bump of the smaller chambers but a few buddies are saying I should go with the LS6 2.5 heads. Which heads will be better with my setup and why?? Thanks in advance!!
I am looking for maximum top end power
the 5.3s are about 220, which is about as big as i would go with a stock cube motor. otherwise you'll lose so much low/mid range power.
i've seen some of the ls6 heads advertise a runner size in the 230s. while this would make for a killer dyno queen. on the street it is very likely to get beat by a car putting out less power.
something to muse over, maybe call up the tech lines at TR or Tbyrne
Call Tsp I Dont Think Thaey Will Agree That There Is Any Real Difference In Top End Between The 2 Heads
That Being Said I Thought The Ls6 Head Produced A Little Better Midrange But I May Be Thinking Of The Eddlebrocks
