AFR 225 'big bore' 72cc heads on a 346?
I am looking at a set of 225 AFR's with 72cc 'big bore' heads. Will these fit on my 347 with a 3.903 bore? Right now I am running stock GM 6.0L heads. Just want to verify that the AFR big bore heads are the same as the heads I currently have as far as the bore size is concerned...
Thanks guys. IIRC the bore of the 5-layer MLS GM gaskets is 4.100 but I guess I will have to measure to be sure. I hope they are 4.125 because I've heard bad things about cometics. If they are not big enough, how good are the fel-pros compared to the GM MLS's?
You could squeeze by with 4.100 but the gasket will be dead even with the chamber bore. I prefer it a bit inboard so the head has a little more aluminum there to better clamp the fire ring...
Tony
Whats up with your fear of Cometic gaskets?
They are no different than the GM MLS in design and function, not to mention thousands of people have used them with great success, myself included.
Tony
PS....They have alot more to offer in thickness, bore sizes, etc....easy to get what you need and get the right quench based on your piston to deck height etc.
Tony
I've just known people personally who have had problems with getting them to seal completely. In fact, I don't know anyone personally who has had success with them. Also read of a lot of mixed reviews here on tech about them. Seems like its hit or miss really... And with my luck, thats about as certain of a miss guaranteed
I measured the GM MLS's and got anywhere from 4.102 to 4.107 Could be maybe the precision of my calipers or simply within the tolerances of the gaskets themselves.
Well, the information about the cometics is about as false as you can get. Not saying that your friends didnt have issues, but there are ALOT of guys running cometics in boosted applications..Probably thousands.. I personally have used cometics exclusivly, and have NEVER pushed water, or had a problem with the sealing. On my last car, I went to 18psi @ just under 900rwtq and 900rwhp without ANY issues. As a daily driver, it was 800rwhp 850rwtq.
My LSx 454 w/NX direct port runs cometics with no problems as a daily driver in Las Vegas's 117* heat.
99.9% of all the bullshit you read about on the internet is from some kid who had a friend of a friend that knew a guy once. Thats how almost ALL of peoples setups are built nowadays. Everything is based off of unfounded information..
I say, go with the cometics and *** worrying about something that isnt gonna happen..
LOL I know better than to base all of my decisions off the internet, but its just that I have personally seen people with problems getting them to seal. I dunno... I need to give it some thought before pulling the trigger. What could be the absolute worst case scenario if I did attempt to run the AFR's with the 4.100 GM MLS gaskets?
I have ran 4.160 bore and .040 thick cometic gaskets in my boosted application (18 lbs) with no problems as long as you don't have any detonation. If you experience any detonation, it doesn't matter what heads, gaskets, fasteners, pistons, etc you have you will have problems.
The issues with Cometics are due mostly to poor surface preparation.
Clean the block and head decks real well, spray the Cometic with Copper sealant, use head studs and don't look back.
They are the best gasket for your application.
