Iron stroker?
382 all bore = 4.100" bore, stock 3.622" stroke.
382 all stroke = 4" stoke, stock 3.9" bore.
there are variations of course.
So an all bore motor is preferrable to a all stroker, right?
I wonder about the cost? A 4" crank about $2K, pistons about $600, machine work about $400, right?
The all bore is $2.8K for the block, $600 for pistons, and $400 for machine work, right?
For HP, all bore
For TQ, all stroke
Street? Its preference...but I still don't trust all bore aluminum jobs...call me paranoid. If you don't mind the weight, go with an iron 408, I wouldn't (personally) pay for a $2K cranks...but whatever..
and if you by a sleeved block...you shouldnt need any machine work that I know of.
I actually recommended a 346-348 setup first, then a 39x" setup using an $800 crank and $400 block. But whatever you want to talk **** about 100-post boy. I would NEVER pay 2400 for a bare block or a crank. I could build a whole SBC for that.
Your the one whos pissed off........ doesnt bother me your mad..... Do things the way you want and when they blow up in your face ill be waiting here to laugh at you. Now you have a nice day. I have better things to do then argue on the net.
Your so smart you didnt even see why i went with that cam. Im not worried about N/A power. Just want it to hold togeather long enough till i do my bottom end. MTI just tuned to tide me over till my D1-SC is on.
ok, back on topic.
My pics for a motor (idependent of H/C/I)
346
396-iron
382-alum.
414-iron
422-alum.
my choice would be to sacrifice $$$ cubic inches and go solid roller; i.e. i'd take a 346 sr vs. a hyd 396. If you can afford both...more power to ya.
....they have a nodular iron 4" crank for $950 USD....
Do you realise we are in Australia?
We manufacture a nodular cast iron crankshaft in 4.00" stroke to suit
the Chev LS-1 engine.
We also manufacture a matching "I" or "H" beam (both)4340 steel conrods
to suit our crank.
Our crank has Ford 302W rod journal diameter and width. Our conrods are
6" centre to centre length and we are waiting for a custom made cast
alloy piston to suit our combination for steet use (arriving very soon).
We will offer customers a complete crank, rod, cast piston package
including, rings, bearings, new steel/alloy keyed harmonic balancer and
flywheel assembly. Balance is external like a 400ci Small Block Chev,
Ford 302 etc.
You are welcome to buy only the crank and use whichever rod/piston
assembly you prefer. The crank only is $950.00 U.S and is available from
our distributor in the U.S Marvin Miller Manufacturing in Whittier
California.
They do not have stocks yet but will in the next month or so.
Hope this helps. Let me know if you have further queries.
Sam Blumenstein
"Bartsch, Robert" wrote:
> I'm interested in a stroker crankshaft for an LS1 engine. Please let me
> know if you are manufacturing these.
Oh, by the way, the AUSIE guy said his cranks carry main journals the size of FORD 302s ??????
Why would you do this? Does'nt this increase the cost of after-market rods and pistons for a stroker package???
Keep it on topic.
