LS1 heads/5.3 block
Old Nov 13, 2007 | 05:25 PM
DopdBrd's Avatar
Default LS1 heads/5.3 block
Will the LS1 heads fit on a 5.3 liter block out of a truck??? Guy here at work wants to stick them on the 5.3 so he can get the fast 90mm intake.
Old Nov 13, 2007 | 05:58 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
Yes, they will fit. They are all interchangable. You can fit a fast 90mm intake on any cathedral port head.
Old Nov 13, 2007 | 08:53 PM
sv650lex's Avatar
watch out when you put the heads on. The ls1 heads have a larger combustion chamber and will lower your compression ratio.
Old Nov 13, 2007 | 09:15 PM
454SuperSport's Avatar
yeah, fast 90 will go on the truck heads, wouldn't do it though unless he's got some serious mods.
Old Nov 13, 2007 | 09:29 PM
mullenh's Avatar
putting ls1 heads on a 5.3 is not an upgrade in performance. you would do this if you increased displacement, or if for some reason you needed to lower compression. a 5.3 head swap is an upgrade for and ls1 because it increases compression with its smaller chamber. with some good machining it will flow well too.
