Broken valve spring
Old Nov 13, 2007 | 06:19 PM
2000KnightRider's Avatar
Default Broken valve spring
On the way back from getting some fine tuning done on my T/A, I noticed a "machine gun" sound coming from the drivers side of my engine. I stopped on the side of the road and a friend towed me to his place and I opened my valve covers and found 2 valve springs snapped in half on the drivers side. I ran my car for about 8 to 10 miles on the broken valve springs. I found a piece of a valve spring and valve seal ring sitting in the head bolt section of my head. I was wondering what are the chances of any shards ending up in my block.
Old Nov 13, 2007 | 06:25 PM
vettenuts's Avatar
If they drained down with oil they should come out with an oil change and magnetic plug. I would be more concerned about the valves hitting the pistons while you were driving it.
Old Nov 13, 2007 | 06:28 PM
DaddySS's Avatar
I don't think debris from the spring or seal will be a problem, I would be concerned with how much banging the valve did against the piston. Replace all the springs and seals, change the oil and fish the pan with a magnet and see what you have from there.
Old Nov 13, 2007 | 07:00 PM
I havent taken the springs off yet but from what I can tell so far the inner springs held up.
Old Nov 13, 2007 | 07:04 PM
5.3LJimmy's Avatar
What springs are you running and how many miles?
Old Nov 13, 2007 | 07:12 PM
santiago's Avatar
my motor gave way after driving on a broken valve spring. i changed the broken one out and replaced it and it still blew up i guess the valve cracked the piston.
Old Nov 13, 2007 | 09:07 PM
REV dual springs. Unfortuneltly my dumbass bought them used with 8000 miles on them. I guess I deserve that f*ck up.
Old Nov 13, 2007 | 09:14 PM
vaticano's Avatar
damn that sucks. i broke two sets of double springs and one set of valves before i found some good ones
Old Nov 13, 2007 | 09:33 PM
Blu99T/A's Avatar
Yeah really sucks that they barely lasted 6 weeks with no WOT runs.
Old Nov 13, 2007 | 09:39 PM
Redlinez's Avatar
It happened to me years ago and I was able to just install new springs and drive away. I guess I got lucky. I'm pretty sure I was running single coil springs too.
