: ( 6.0 MS4 Question
Old Nov 15, 2007 | 02:00 AM
ThaBirdMan's Avatar
Default : ( 6.0 MS4 Question
So here's the deal.
I'm doing a 6.0 build. Im using the stock shortblock from a 6.0 truck motor. It has the Dished Pistons.
Now i know on a stock cube ls1 engine, you can run the ms4 with just barely enough valve/piston clearance. Well, i have some Stage 3 Patriot heads that have been Milled slightly. Now i know if that was going onto a stock cube ls1 we would be having some issues with clearance, but since i have the dished pistons maybe i might be ok?
if not, what if i picked up a set of thicker head gaskets? Maybe some Cometics? (if anyone knows the part number on some thick 6.0 cometic head gaskets please let me know ).
I think with the stock dished 6.0 pistons and some cometic head gaskets i might be able to do this without having to flycut my pistons.
Any input would be highly highly appreciated.
Thanks.
Old Nov 15, 2007 | 08:52 AM
ls1leadfoot's Avatar
yes ms4 will work with a thicker gasket and the dished pistons......i have the same setup and ms3
post up some audio clips when it runs i would like to hear that
Old Nov 15, 2007 | 06:24 PM
ThaBirdMan's Avatar
So even though the heads are slightly milled it will be fine, and i wont have to flycut?
Believe me, there will be plenty of vid's once we are finished. It's a garage project so im taking my time. Hoping to be done in the next few weeks.
Any more info?
Old Nov 15, 2007 | 07:23 PM
1320 killer's Avatar
I have the 6.0 liter also with a huge cam. makes great power but a little loud. for street drivng I want to go back to the ms3
Old Nov 15, 2007 | 09:04 PM
ThaBirdMan's Avatar
and the heads are milled 20 thousands.... if that helps.
Old Nov 15, 2007 | 09:14 PM
ThaBirdMan's Avatar
and also i have the 7.4 pushrods, will this be ok with the milled heads and that big of a cam..?
Old Nov 16, 2007 | 12:02 AM
chewy99ws6's Avatar
I don't have milled heads but I do have the MS4 with stage 3 heads and I am running -4cc dished pistons and I don't have any clearance issues.
Old Nov 16, 2007 | 12:12 AM
ThaBirdMan's Avatar
How much are the pistons dished on the 6.0 stock?
Old Nov 16, 2007 | 12:40 AM
around $600 for some diamonds
Old Nov 16, 2007 | 01:09 AM
ThaBirdMan's Avatar
Lol no, i meant how many Cc's is the dish in a stock 6.0 piston.
Anyone know about the pushrods.
Part # for some thick head gaskets too.
Old Nov 16, 2007 | 11:38 AM
ThaBirdMan's Avatar
t.t.t for today cam should be here any day now
Old Nov 16, 2007 | 12:39 PM
Tri5Nerd's Avatar
They should not be dished on a stock 6.0L, remember that your stock compression will be lower than a LS1/LS6.
Old Nov 16, 2007 | 02:51 PM
ThaBirdMan's Avatar
well these i have are dished. i bought the whole short block from a guy off here and the arent flat all the way across them like my 5.7 ls1 pistons were,, they have a dish all the way around it, not dished for the valve they just arent flat all the way across, dished may be the wrong term to use but i dont know how else to explain it.
its like theres a raised edge around the outer edge of the piston about a quarter of an inch around the circumference then they dish down in the middle of the piston not sure how much tho...
Old Nov 16, 2007 | 03:06 PM
topher455's Avatar
The engine is a 6.0 lq4 and comes factory with dished pistons. The comp ratio is 9.4 to 1. The lq9 had flattops and comp is 10.1 to 1. If the heads you have are 243 castings and theyre milled .020 comp should be about 10.7. Stock 317 6.0 heads are 72 or 74 cc cant remember and the 243's are
64 cc minus whats milled. Stock 243's on a lq4 yields 10.4 to 1 comp so that is my estimate. You should be very careful with cam selection or your static comp may be too high. Pay close attention to your valve overlap. See the cam sticky to figure out how to compute it. Hope this helps.
Chris
Old Nov 16, 2007 | 03:56 PM
ThaBirdMan's Avatar
It does help, I believe my heads have 64cc chambers. They are the patriot Stage 3 6.0 heads. I dont know if what difference that makes but...
Any more info guys?
Old Nov 16, 2007 | 06:58 PM
Tri5Nerd's Avatar
My bad, I was referring to the LQ9 engines.
Old Nov 16, 2007 | 08:18 PM
hammertime's Avatar
Personally, I would not recommend going to a thicker gasket for valve clearance. I would recommend checking the deck clearance (the distance the pistons are in the hole, or exposed from the hole, at TDC), running a gasket that puts the piston within .030 to .035 of the deck at TDC, and checking for adequate clearance (usually .080" Intake, .100" exhaust).
Moving the cylinder head deck away from the piston reduces the squish in the chamber as the piston approaches TDC, and ultimatley makes the engine more prone to detonation, despite the slightly lower compression ratio.
If the original poster is going to run the MS4, even 10.7:1 may be on the low side for what that cam wants. Using PianoProdigy's DCR calculator, I figured a 7cc dish and .055 thick gasket would give approx 9.4:1, and 0 dish gave 10.1:1. With a 64cc head milled .020, the compression with dished pistons and a .040" thick gasket comes out to 10.84:1. The problem is, that cam bleeds a lot of cylinder pressure with it's late closing intake valve, so the Dynamic Compression comes in at less than 8:1.
Overlap will not affect the dynamic compression, but the VE's that generate more overlap (tight LSA, longer durations) are more likley to create a valve clearance issue
Old Nov 16, 2007 | 09:47 PM
ThaBirdMan's Avatar
You dont know how much this helps me guys.. keep the info coming! thanks!
Old Nov 17, 2007 | 08:49 AM
s346k's Avatar
i also have an lq4 shortblock that i plan on using for a build. just for giggles - what kind of compression would be seen using the stock shortblock and a 59cc l92 head?
Old Nov 17, 2007 | 01:30 PM
ThaBirdMan's Avatar
Ok, Scratch the 64cc chambers.
I actually have the stage 3 lq9's with 72cc chambers.
Any different?
