How do I know which way to install Eagle rods?
Old Nov 15, 2007 | 11:19 AM
blackbird345's Avatar
Default How do I know which way to install Eagle rods?
Am I suppose to install the eagle rods with a specific side facing the front of the engine or does it not matter?
Old Nov 15, 2007 | 11:24 AM
fuseone's Avatar
not sure but i know on some engines they do got to .
Old Nov 15, 2007 | 12:11 PM
BlackScreaminMachine's Avatar
Internet Mechanic
Im rebuilding my LT1 block this sunday, there was nothing showing a specific order had to be followed.
Old Nov 15, 2007 | 12:55 PM
1320 killer's Avatar
yes it does matter and there should be a small arrow on the side of the rod that should be pointing to the front of the motor. if not there i would contact eagle and ask if it's necessary.
Old Nov 15, 2007 | 01:10 PM
Internet Mechanic
I'll double check when I get home, I know my rods are # but ill check on the Arrow.
Old Nov 15, 2007 | 02:11 PM
N2DP2QT's Avatar
there should be a flat spot on the diameter of the rod where it bolts to the crank. one side is a thicker machined spot than the other. install the widest ones towards each other. if that makes any sense
Old Nov 15, 2007 | 09:44 PM
mrr23's Avatar
for a LS1 motor, the offset of the rod all face the same direction. i want to say the large offset goes to the front, but don't remember for sure.
Old Nov 16, 2007 | 08:31 AM
xssive's Avatar
on the crank end, the chamfered side faces the crank throws, and the flat sides will face eachother
Old Nov 16, 2007 | 11:35 AM
Firechikn's Avatar
+1. If you look closely, where the rod touches the crank, one side is beveled and one side isn't. The non beveled sides should be together. When you put your pistons on 4 should be one way, the other 4 the opposite. Look closely, you'll see it.
Old Nov 16, 2007 | 01:01 PM
1997bird's Avatar
You should always install the rods with the bearing retention tang facing up while the motor is rolled over on the engine stand looking at the crank.
