Patriot Predator Flow Numbers!
Old Nov 20, 2007 | 03:13 PM
Gunnar@Patriot's Avatar
Guys, these heads are a 200cc CNC ported runner. Not quite sure what heads you are comparing these to, but our heads flow right with other competitors heads while being 5-10 cc's smaller. Please let us know if you have any questions.
Old Nov 20, 2007 | 03:30 PM
t-1's Avatar
t-1
better velocity i would assume then
Old Nov 20, 2007 | 04:19 PM
big reg's Avatar
Originally Posted by SilverSmoke
Hmmm, just looking at numbers alone, doesn't look like these pair up to an AFR 205 set as I was thinking, or others on here above. Is everyone contemplating these heads will be hand ported to push out some nice numbers?? This is what I'm thinking, but could be completely wrong...
Not sure where you are getting your info from but check the flow #'s Gunnar posted to these found at Speed Inc's site for CNC'd AFR 205's with 66cc chambers. http://www.ls1speed.com/artwork/flow/afr1510.jpg According to my research they match up very well espec considering the $500 price difference
Old Nov 20, 2007 | 04:24 PM
00BlackSS's Avatar
cant wait to see the 220 and 245s!!! really intreseted in those and see the price!
Old Nov 20, 2007 | 05:21 PM
SilverSmoke's Avatar
Ah! Okay, I'm sorry, looking at something different, not the advertised as cast heads. This was what I was originally comparing to:
"h"....142...202...260....303....316....323... ..24 9 cc's....Hand ported 205 casting
AirFlow Research #’s
205….145….210….257….290….301….308………205 cc’s...(205 w/ 4.125 #’s)
So I wonder if there is any room for a bit more porting for some higher flows for the guys who want good balance of power and power under the curve???
Old Nov 20, 2007 | 06:28 PM
DrkPhx's Avatar
Originally Posted by Gunnar@Patriot
Patriot Gold dual springs (Xtremes optional),
Gunnar - Are the Xtremes a new valve spring you offer? What are the details?
Old Nov 20, 2007 | 07:12 PM
Steve Bryant's Avatar
LS1 Tech Veteran
The Predators should represent a super value no matter which intake runner/combustion chamber/springs/etc. you choose. For street use, the 200 cc with the kind of high velocity energy that they'll produce should work great for most of us. I'm going to use them on my 408 with a 70 to 72 cc combustion chamber. For a more single-purpose, strip engine, you can go with the 220 or 245 and the price is still the same. I'm sure that the high-lift flows on those heads will be way up there but the low to mid lift numbers won't be as good for a daily driver.
I can't wait!
Steve
Old Nov 20, 2007 | 07:34 PM
big reg's Avatar
That makes 2 of us. 64cc chamber 200cc Predators should go nice with the new Street Warrior manifold coming out. I know what my next round of mods are!
I can't wait!
Steve
Old Nov 20, 2007 | 09:32 PM
MPHmotorsports's Avatar
This springs is almost a year old now.
It is very similat to the regular gold. I think it uses the same outer spring but a better inner. Its is rated for .660 instead of .650
Old Nov 20, 2007 | 09:52 PM
PLEASE READ THIS POST IF YOU GUYS HAVE POSTED OR BEFORE SOMEONE POSTS AGAIN.
It seems many of you could use some help with the design/flow of these heads.
There is NO reason to port this head any further.
The point to this head is a great flowing head using a small runner. This has proven to be a successful combo with AFR/ETP/TFS/Dart etc. This head should make killer power, while having a awesome torque curve and great Throttle response.
This head is tailored to a specific crowd, and that is the reason they also have a 220cc and 240cc head coming out. Big Red has the right idea. Combined with the right set of mod's your could have a killed package with a head that is 600 dollars cheeper then the comp. Also on the #'s posted above the AFR 205's are on a 4.125 bore. That makes the flow number a bit better then if they were flowed on a 3.900 bore or 4" bore.
Speaking of which Gunner what bore fixture did you use?
Basically this head has the potential to compete with some of the other top quality heads but for a lot less money. Porting further would defeat the purpose. Now you are buying a head based on price, but by the time you take the head apart, have them ported, cleaned, reassembled, and re flowed you could have just purchased a ETP or TFS head. If your looking for a better top end flowing head I am sure the 220cc head will be better suited for you.
Hope this help's some of you understand this product. Only time will tell how good they are compared to the other big togs, and at this price I am sure we should have some people providing number's for us shortly.
Thanks Patriot for bringing another quality head to the market and good luck.
Old Nov 20, 2007 | 10:54 PM
hammertime's Avatar
I've been watching this thread for a while now, and I have to say: Best post in the whole thread. I don't think this head is presented as a world beater, but this could be one of the best valued, street oriented heads available to the market.
Anyone who wants to continue porting this head after purchase and match it with your 230+ cam, go right ahead. Don't be surprised though when another guy with an untouched predator head and a 220-224 cam eat's your lunch up to 5000 rpm.
Old Nov 21, 2007 | 12:02 AM
  #32
Vrbas's Avatar
Old Nov 21, 2007 | 12:44 AM
  #33
deeloc1's Avatar
I'm wondering how this head would do with a f13 cam (230"/232" .595"/.585" 112LSA). I was looking very hard into purchasing the AFR 205's at the beginning of next year and would be very interested in these heads if i am able to get good results with them. The f13 and afr 205's are a proven combo but If these Predator heads are made to be matched with cams below the 228 range, i'll stick with the AFR's. Guess i'll just sit back and see how these Predator heads do until i'm ready to purchase my heads in January.
Old Nov 21, 2007 | 09:29 AM
  #34
I just posted those numbers as I didn't want to mislead anyone or anything on my misunderstanding alone (regarding wrong numbers I referenced), that's all. Yes, bore is larger 4.1" on the measured numbers.
Gunnar made a seperate post regarding this head, on a seperate thread and was completed on a 3.900" bore.
So now given this new introduction, you guys are screwing with my head in what to get now for Tqr II cam!!!! Predator, TFS as-cast or AFR, ugh... how long do I have to wait now?
Those exhaust numbers are pretty high on the higher lift end.
Old Nov 21, 2007 | 10:04 PM
  #35
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
We will be offering these in 59-72cc heads.
Are they available unmilled in those sizes or are they general sizes and then milled down to the desired size?
Originally Posted by 93redBIRDman
Is it just me or is 290cfm @ .550 not impressive for over $1,700??
It's just you.
+1 Predators + Weiand intake will be more than likely going on my backup forged 347.
Old Nov 27, 2007 | 01:01 PM
  #36
TTT
Any updates?
Old Nov 28, 2007 | 08:30 AM
  #37
The Xtreme springs are a spring we came out with last spring. It is much like the Patriot Gold, but the Xtreme has 150 lbs on the seat and around 410 open. It is for the more aggressive cam profiles and boosted cars.
We will use a combination of chamber designs and milling.
Old Nov 28, 2007 | 09:53 AM
  #38
The Alchemist's Avatar
UNDER PRESSURE MOD
A couple quick questions:
What would the cost be minus springs and retainers? I run a TR224 cam and don't want or need the added weight of a dual spring. I prefer to stay with the 918's as I have had good success with them and already have the titanium retainers.
Also, with the 59cc chamber, I know you replied that it's a combination of chamber designs and milling, but would I be risking piston to valve clearance issues with a 0.040 gasket and a TR224 cam?
Thanks.
Old Dec 1, 2007 | 04:46 PM
  #39
HotRodV6's Avatar
The flow numbers look really good on these heads. And im thinking the 220 runner heads will go really well with my E85 383 Engine build that will be running a turbo at around 15-18 PSI.
These may end being the next best thing to running L92 heads especially for the guys running less that a 4" bore.
Old Dec 1, 2007 | 05:21 PM
  #40
silver-mod-o's Avatar
Custm2500's #1 Fan
seems like thsese would work pretty well with my combo...
5.3L LM7
LS6 intake
Custom 224/227 113+3 cam
dual stage shot of the goofy gas...
hhhmmmmmmm hurry up Tax return!! LOL
