Patriot Predator Flow Numbers!
#42
OWN3D BY MY PROF!
The flow numbers look really good on these heads. And im thinking the 220 runner heads will go really well with my E85 383 Engine build that will be running a turbo at around 15-18 PSI.
These may end being the next best thing to running L92 heads especially for the guys running less that a 4" bore.
#46
Wow.. a 200cc runner + high DCR is gonna have crazy throttle response and low end. Top end probably won't be affected since the plastic intakes (even ported FAST 90s) lop off flow well before 300 cfm. Too bad I just ordered stg 2 LS6s.
