TSP torquer vs2.....Not impressed
Old Nov 29, 2007 | 09:09 PM
  #101
mzoomora's Avatar
14 Second Truck Club
Originally Posted by nitrojunky
Looks like it would need to be redlined at >7k rpm to make use of the power. Do these cams usually require spinning the motor that high? If not, I'm going to jump of the 'one tooth off' bandwagon.
Actually after looking at that dyno graph closer I would have to agree with you. I guess I never really paid that close of attention to the graph. I dont remember how many teeth the cam gear has, but I think I figured before that one tooth off was about 8 degrees or so.
Old Nov 29, 2007 | 09:42 PM
  #102
DaveX's Avatar
Originally Posted by LS1HIGHLIFE
I won't be able to check the gear alignment this weekend but I should be able to check te push rod length and compression. I know that each cylinder should be within 5% of each other but what PSI should I expect to see on a motor with 79k mi?
Depends on your DCR.
Old Dec 1, 2007 | 05:35 PM
  #103
LS1HIGHLIFE's Avatar
???DCR, compression ratio? Acronyms I live with them everyday but don't knoem all
I checked my compression PSI today which was a bitch BTW on the passenger side. Everything came out +/- 5% of each other except for number one piston. My numbers were as follows:
Piston PSI
1 178
2 190
3 180
4 190
5 186
6 185
7 201
8 185
I have a micrometer coming in to check the pushrods next weekend and I also need to pull the timing cover off as well. What do you guys think about these reading I got today?
Old Dec 5, 2007 | 08:13 PM
  #104
subhumanzz's Avatar
bump it up for some info!
Old Dec 5, 2007 | 09:41 PM
  #105
GT Griller's Avatar
Originally Posted by sidewayz28
yeah well i had 2 918s break with the torquer2 as well...
Originally Posted by LostCauseZ06
the faulty batch of 918's cant handle a stock cam.... let alone a T2... lol
20 bux says if you pull your valve cover you will find a nasty surprise, do a search for broken 918 springs and i think it will make you sick
I didnt say i recomended them....lol...just that they do work...my buddy has been running them for a long while now with his Torquer 2 and has added spray on top of that.....no broken springs....thats not to say it wont happen tho.
Old Dec 7, 2007 | 08:54 PM
  #106
"CORRECTION- I have stock ported 853 casting heads"
Alright so I pulled off the front cover today and found that my gear alignment was spot on. So I called Jason up at FBC and asked what else could I check that may be giving me issues. He said that if I degreed my cam that I may have found it to be off a few degrees so I may need to adjust the gears. I don't have a way to do this, nor do I know how really. I tried to check my push rod length with a length checker but that didn't work. So I tried Jason's way by opening the intake valve all the way up and finger tightning the rocker until it was snug. I got about 1 turn on the bolt before I go to 22ftlbs.
Does this mean I have too long of push rods or what? Or, are my lifters going out? My engine sounds horrible....Or are the valve size in my heads just not good enough for this cam?
Old Dec 8, 2007 | 10:03 AM
  #107
BLK02WS6's Avatar
Damn, I thought sure it was off a tooth the way it is acting. You sure the bottom sprocket is on the right keyway (if it is the kind with more than one)? Would be best if you could degree it to check it, but I understand if you don't have the stuff or know how.
I'm not sure what they say for preload on the lifters... might wanna call J back and ask him how many turns... I thought it should be more than one, but don't remember what they use...
I'm at a loss now man... if it were mine, and I couldn't degree it, I would probably go ahead and advance it 2 degrees while the front cover is off and dyno it again to see if the torque picks up. It wouldn't cost you anything but time and would at least tell you if you were on the right track. Don't know what else could be up given all the other variables you checked/didn't change...
Old Dec 8, 2007 | 03:21 PM
  #108
bad6as's Avatar
i didnt read that your timing set is adjustable
 Michael S. Palmer
Old Dec 8, 2007 | 05:19 PM
  #109
99blancoSS's Avatar
compression looks good from that test, I'm guessing you just used a compression tester. What about a leakdown test?
here is a good link for general use
http://www.geocities.com/dsmgrrrl/FAQs/leakdown.htm
Old Dec 8, 2007 | 05:21 PM
  #110
DaveX's Avatar
DCR = dynamic compression ratio. Which is your static compression ratio minus compression that bleeds off from valve events due to your cam. The higher the number the higher your compression readings will be.
Old Dec 19, 2007 | 05:45 AM
  #111
Yeah it's a SLP double roller adjustable one with different key-ways to adjust timing.
I'll have to give Jason a call after the Christmas/new years thing and get more info. I found an LS6 intake manifold to get rid of the aluminum one. Now I just need to try some other trouble shooting when I get time.
Thanks Guys.
Old Dec 19, 2007 | 05:48 PM
  #112
will69camaro's Avatar
Sex On Wheels
I've only heard good things about that cam so I think once everything is sorted out you'll be happy. Friend of mine with ported 243's and that cam with all boltons (no fast) did 450/420! I almost want to lose my TR230/236 for one but I'll wait until I see what I can get out of it.
Good luck man, TSP is a good bunch, i'm sure they'll help you figure it all out.
William
Old Dec 19, 2007 | 07:01 PM
  #113
William
Yeah those are the numbers I was expecting to see. We'll see in a few weeks what happens. What dyno and where did your buddy get his done? What are all his mods specificlly? Thanks.
Old Dec 19, 2007 | 07:11 PM
  #114
BLK02WS6's Avatar
I'll be gone for the holidays, but let me know if you find anything and when you want to bring it back by to dyno it again... I really hope you find the problem, its been bothering me
Old Dec 19, 2007 | 08:33 PM
  #115
BOWTIE's Avatar
I am not sure how the SLP is marked, but most of the multiple keyway crank gears I have used in the past will have 2 set of identical marks, one marks which keyway to use, the other is the one used to align with the cam gear. If you line up with the wrong mark, your cam timing will be way off. Do not relly think that is the issue here, as it still seems to run ok, but just food for thought.
Old Dec 20, 2007 | 09:20 AM
  #116
z-ya's Avatar
Make double sure you used the correct indexing marks on the adjustable gears on the initial installation!!!
Old Jan 9, 2008 | 09:59 AM
  #117
Yeah I made DAMN sure the gears were aligned corectly by having three people take a look at it.
Update: I went with an LS6 intake manifold and got my cut-out put back in. After speaking with John from Khaotic Kreations and getting some info from "Patric G" and info from Cam motion, even if I advanced the timing on the cam 4 degrees I will not much of a power increase. The only way I will see an increase to put me back/over my old 224 numbers would be to go with bigger valved heads that flow much better than these 853 castings. Thats about all I've been able to come up with on the power drop issue, A miss-match of heads/cam....................
Old Jan 9, 2008 | 10:15 AM
  #118
JS's Avatar
JS
We have had very good results with the Comp 54-446-11..
Its a stout performer in the right application and make great power to 6500
Old Feb 8, 2008 | 08:53 PM
  #119
Default Update!
I got my PRC 2.5 5.3ltr heads in!!!!!! I hope that by upping my compression my car will perform the way she should with this cam. Maybe next weekend when I have some time I'll install them.
I'll be sure to give you a call when there done Bret!
Old Mar 3, 2008 | 09:31 PM
  #120
Default Got er tuned and running GREAT!
Big thanks to Eric"subhumanzz" for helping me out with the install and dealing with the long hours. It was fun!
And another big thanks to Bret Shook "BLK02WS6" at FBC for working with me on getting my car where it needed to be. I appreciate your help and if I had more green this evening it would have been yours. Best wishes to you and your family. Let me know if there's anything I can help you with.
The little ole lady threw down 433/383 uncorrected and 426/376 corrected. I'm happy!!!!!
