TSP torquer vs2.....Not impressed
MY DYNO SHEET LOOKS EXACTLY LIKE THAT
MY CAR THREW DOWN 411 @6450 WHICH IS WERE THEY LEFT OFF THE GAS
THE GRAPH DOESN'T STOP CLIMBING FROM 3- ON UP
I DID NOT DEGREE OR HAVE ADJUSTABLE TIMING SET SO I HAD NO CHOICE TO PUT IT STRAIGHT UP AND DOWN.
What else I wanted to say was, if the old combo ran so good go back to it.
There are to many variables in this. Especially with the dyno recalibration. I wasn't there I don't know anything about it and I no way am I bashing anyone, thats not how I roll. But if you tell yourself the car is slower and convince yourself of it. When you drive the car is going to feel slower. The placebo effect, the mind is a powerful thing. Just ask all the people that took the sugar pill.
I agree, something was wrong what I don't know. This is all speculation, but this is what I think.
The dyno was off, waay off in the beginning. Because to "feel" a power increase on the butt dyno, you need what? 15-20hp at least? Going to better heads and a better cam I would hope you would get more than that. So if the second set of dyno numbers are correct and they are less the original number, the first number HAS to be off....a bunch.
The other option is the cam was ground wrong. Yes it was dot to dot(which I think most people do)and not degreed there's no way of knowing. And for the cam being to much for the heads, I think there are a lot of people running bigger cams than that on stock headed motors and making more power. I would have to go back and look at the cam specs but I don't think it's bigger than a MS3 or MS4 cam.
There's been a lot of big dyno numbers posted in this thread from cam only cars and H/C cars, especially on mustang dyno's.
I am glad you are happy with your car. I just think you would have been just as happy and have a little more money in your pocket if you went back with your original setup. If it was me I'd be pissed to spend $1600 and be back where I was. I think it was just a bad situation all around.
And another big thanks to Bret Shook "BLK02WS6" at FBC for working with me on getting my car where it needed to be. I appreciate your help and if I had more green this evening it would have been yours. Best wishes to you and your family. Let me know if there's anything I can help you with.
The little ole lady threw down 433/383 uncorrected and 426/376 corrected. I'm happy!!!!!
