NEW LSX Intake Mainfold better then FAST
![Exclamation](https://ls1tech.com/forums/images/icons/icon4.gif)
If this comes out and backs up its claims screw the FAST 90/90 setup I was going to do when I do my heads this winter I'll go this route. About time someone came out with a composite intake to rival FAST that does not include the insane price of the FAST combo.
http://www.v8tvshow.com/forum/index.....msg437#msg437
LS1 Tech Administrator
Don't hold your breath. Early reports show the runners in the Weiand manifold to have smaller cross sectional area and longer runners than both the FAST 90 and the LS6 intake. What this means is that the Weiand manifold will make better torque and hp at lower rpm, but it will run out of breath above 6000 rpm.
Even Weiand's own dyno sheets show it being passed up by the LS6 and FAST intake above 6000 rpm. If you're looking for a great street manifold, this is worth considering, but if you're looking for something that makes lots more peak power than the LS6 or FAST 90, you may want to wait for some unbiased 3rd party testing.
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic210_1.gif)
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
yeah I was planning on waiting for someone else to be the guini pig of course but seeing as the stock redline on the engines its made for (LS1,LS6,LS2,L92) is 6000-6500 I cant see them not being prepared for this piece to go on a modded car considering it is a mod itself, guess time will tell.
The nice part is they will bring out a L92 head compatible unit
The untouched ugly truck manifold outperforms the LS6 manifold on 5.0L Daytona Prototype engines which make max power ~7000. I believe those engines make the kind of power most 5.7 and 6.0 LS engine guys would be proud of.
Runner length should be pretty easy to measure @ PRI.
Good to see more products come to market. It does kind of suck that it drops off. How does the torque or a FAST compare to this? They said 30something lbft at 4000?..Where does the fast come in on torque?
The L76 manifold is similar. It has a large runner but has a long runner as well, this hurts the top end potential of many combo's.
I think this manifold will be a great street manifold and depending on the price... might be a good move for the 98-2000 guys who dont have a LS6 intake manifold already.
it sounds like the new weiand would be great for an autocross application where most of the time is spent in the 4500-5500 range if you are geared right. extra torque when you are only flashing higher rpms once in a while is very helpful.
Whats the runner length of the FAST and LS6 manifold? Also, when it comes to sheetmetal intakes, what do their runner lengths usually end up at?
Sorry for the hijack.. Just trying to get an idea of how these all stack up..
Yep.... If you know how manifold's work then then common since will tell you this manifold will struggle to 7,000 RPM's. The long runner will make for more downlow power/TQ but will hold back the up top RPM range.
So does the manifold now flow as well as an LS6 6200rmp+ or will it still be a slight upgrade over the Ls6? Even if it were a slight upgrade, it might be worth it for the added low end torque you would see...?
You want power under the curve. The first 60' the low and mid range are important, but after that, it's pretty much all top-end.
__________________
