how long do I have to wait for WOT...?
Old Jun 19, 2003 | 05:22 PM
Assassin's Avatar
Default how long do I have to wait for WOT...?
I have about 180 miles on er so far, some say after 200 mi, how long should I go, I've been slowly giving it more rev's and a little bit harder throttle, but not going above 2500 rpm, should I just take it slow, and every day after so many miles just give er a little more revv's, or what?,
new mods: cam, pushrods, valve springs, timing sprocket and chain, gaskets & bolts(duh), headers, non platinum plugs (gap 45), and.... yeah...
btw, I've been monitoring all fluids and guages, so far so good!
Old Jun 19, 2003 | 05:29 PM
Ed Blown Vert's Avatar
Default Re: how long do I have to wait for WOT...?
I would have done it 80 miles ago. Wait I did!
Have you changed your oil yet??
Old Jun 19, 2003 | 05:34 PM
Assassin's Avatar
no, I'm going to change the oil after one tank of gas!
Old Jun 19, 2003 | 06:21 PM
Mustang Hat'r 2's Avatar
Once you heat cycle the valve springs get it hot then cool down do that 3 times then go out and enjoy it. You dont have to break in a cam headers, heads, and all that the only time you would want to baby it like that if the short block was new. Like new piston rings bearing crant. I had 1/2 mile on my cam before I took it to 6k I heat cycled the springs in the drive way and then let her rip.
Old Jun 19, 2003 | 08:26 PM
Slowhawk's Avatar
LS1Tech Sponsor
Your all set like is being said.I ussually heat cycle them twice in the driveway,then drive it 10 or so miles and let it cool.Change oil and let her rip.
Old Jun 19, 2003 | 08:29 PM
Smoke_Ford's Avatar
changing oil is the biggest part.
