yella on stock engine
Old Nov 19, 2007 | 10:34 PM
crazymofo1986's Avatar
Default yella on stock engine
friend is getting rid of his 1.8 yella terra's for $300 bc he has to get 1.7 for his new cam. is it worth me installing this a my car that has 130,000 miles and only has lt headers, intake and tune. not going to have cam or heads. if i do go with this what should i expect. also should i buy anything else? am i going to need new shims? i really know nothing about this if you can fill me in. thanks ahead of time.
Old Nov 19, 2007 | 10:39 PM
SSpdDmon's Avatar
They'll bump your stock cam lift ~.030 to ~.525, which means you'll need a new set of springs too. So, plan another $75 for LS6 springs. Horsepower gains will probably be in the range of 10~15 at the tire. And, you may need to revisit your tuner - especially if he had you dialed in at a 13.0:1 AFR because it'll most likely lean you out up top a bit.
Old Nov 20, 2007 | 12:48 AM
BOWTIE's Avatar
If they are not the new style, i think I would pass. You can get the new revised versions for about $385.00.
Old Nov 20, 2007 | 04:44 AM
vettenuts's Avatar
I found to get proper wipe they required some shimming, which in turn required longer pushrods, so add that to the cost as well. For that price, I don't think its worth the investment on a 130K motor. Its not exactly a screaming deal.
Old Nov 20, 2007 | 07:09 AM
teke184's Avatar
give him $150....otherwise...pass
Old Nov 20, 2007 | 10:38 PM
he is also giving me ls6 springs and z06 push rods. the guy said i wouldnt need shims and that for diff cams not stock cams. is that true? he picked up these rockers off ebay about 8 months ago. could that still b the new design?
Old Nov 21, 2007 | 05:03 AM
vettenuts's Avatar
To determine if you need shims, you need to do a wipe test. My bet is that you need shims to correct the wipe, it will be too close to the intake side of the valve stem. Not a big deal, but be aware of it. Correct geometry will be critical with the higher ratio.
Old Nov 21, 2007 | 06:19 AM
BlackScreaminMachine's Avatar
Internet Mechanic
Yea, dont spend too much money, original rockers with the exception I beleive SLP were very heavy
Old Nov 22, 2007 | 03:07 PM
dmiz0420's Avatar
z06 push rods may be too long as the z06 cam had a smaller base circle.
I am happy w/ my 1.8's, and the tuner couldn't get anything else out of it, my stock computer compensated for this just fine. The a/f was a little lean, 12.9, thats not enough for me to loose sleep.
good luck
Old Nov 22, 2007 | 07:38 PM
did u change only ur rockers on a stock cam dmiz? was it worth it? can anybody else confirm about the z06 pushrods
Old Nov 25, 2007 | 04:31 PM
bump .
