POLL, plastic or aluminum version of FMS intake?
Old Jun 23, 2003 | 05:49 PM
  #61
Visceral's Avatar
Default Re: POLL, plastic or aluminum version of FMS intake?
well, since Im NA for now, and wont be sprayin any time soon, make it whichever way is cheapest, which sounds like plastic.
Plastic intakes can be a problem if you have a n2o backfire. Instead of a taco'd throttle plate you have expensive bits and pieces.
Metal wouldnt be suuuuch a big deal heat-soak wise if it could come with phenolic spacers.
chris
Old Jun 23, 2003 | 07:13 PM
  #62
2000SILVERTA's Avatar
You can test fit one on my firbird if you want.
Old Jun 23, 2003 | 07:32 PM
  #63
Jason99T/A's Avatar
I can shift faster than you.
Allan, I got the graphs scanned and uploaded. Check your mail.
Old Jun 23, 2003 | 08:07 PM
  #64
Futral's Avatar
Here the comparison graph.
Old Jun 23, 2003 | 08:42 PM
  #65
1more's Avatar
dayum....put me down for a plastic one...
Old Jun 23, 2003 | 09:08 PM
  #66
Camaroholic's Avatar
Looks like if you don't pass 6200, you wouldn't benefit by this intake. That's right where my dyno graph flatlines as well.
I'm raising my limiter to 7500 this week. Sign me up... I'll take Plastic.
-Andrew
Old Jun 23, 2003 | 09:10 PM
  #67
Futral's Avatar
Not sure how the intake will work on a "stock" motor since it was designed as a race intake,and will labeled as such. Both versions should be able to take 20lbs+ of boost easy. Right now,we are street testing and track testing the intake for results.
trucks,never thought about that. Guess I will have to look into that.
Old Jun 23, 2003 | 09:14 PM
  #68
XLR8NSS's Avatar
Adkoonerstrator
Hahah...Yeah, let LOTSOFUN test one out. It looks like most truck guys won't benefit much though since most of the gains are above 6200 like Andrew said earlier.
Do you think these would benefit a blown motor any that isn't spinning much above 6000rpm??
John
Old Jun 24, 2003 | 01:05 AM
  #69
Fenris Ulf's Avatar
was that 20rwhp gain over the LS1 or LS6 intake?..im interested in one if it's over the LS6..any flow numbers on the intake or a head with the intake bolten on?Finally a decent intake!!!!
Im gonna take a guess and say his 10 second heads cam car was running an LS6 intake before his custom intake.
One more vote for plastic, gotta keep the weight down
Old Jun 24, 2003 | 11:12 AM
  #70
Formulation's Avatar
I need a plastic one ASAP, do you have any idea on the estimated time until they are ready?
Old Jun 24, 2003 | 11:34 AM
  #71
LEO's Avatar
LEO
Plastic - PLEASE!
Old Jun 24, 2003 | 12:23 PM
  #72
Phil99vette's Avatar
7 Second Club
Looking at the graph the sheet metal intake had more bottom end and top end. There is a small spot where the LS6 has more hp but thats probably tuning related.
Phillip
Old Jun 24, 2003 | 02:18 PM
  #73
The Juggernaut's Avatar
Allan-sent you a PM.
Old Jun 24, 2003 | 04:02 PM
  #74
00 Firehawk's Avatar
Default Re: POLL,plastic or aluminum version of intake?
I vote for the plastic... Im using NOS Pro Race Fogger System with NOZsels in stead of the regular foggers ...
Plastic would serve me better.
Same here!! Prices man...Prices!!
Old Jun 24, 2003 | 04:22 PM
  #75
Skelton's Avatar
Can I get one for use with C5-R heads in plastic? I'm sure sheetmetal could easily be done. Just got a sweet deal on C5-R heads.
Old Jun 24, 2003 | 05:06 PM
  #76
Bad1le's Avatar
Plastic! I'll be a test mule if ya need one
AJ
Old Jun 24, 2003 | 06:53 PM
  #77
xxxhp's Avatar
It would be nice to have that intake tested on blown & big cube motors.
Old Jul 4, 2003 | 08:54 PM
  #78
Nickn20's Avatar
I don't remember if I posted yet but my vote is plastic, I'd be glad to test it out on my new 422, I would give you a before and after dyno.
Old Jul 4, 2003 | 11:05 PM
  #79
91Formula's Avatar
Plastic!!!
Old Jul 5, 2003 | 03:58 AM
  #80
badass 2002 z28's Avatar
I'd like to see some dyno numbers for the plastic version
