POLL, plastic or aluminum version of FMS intake?
Plastic intakes can be a problem if you have a n2o backfire. Instead of a taco'd throttle plate you have expensive bits and pieces.
Metal wouldnt be suuuuch a big deal heat-soak wise if it could come with phenolic spacers.
chris
a burst panel would take care of that, wilson manifolds sells them, would be good for the boosted guys too.....
Oh and BTW, you get NO rematch. I like the crown. LOL
Tim
accufab makes some nice peices, all new, and could probobly do a GP on them
http://www.accufabracing.com/throttl....htm#MustangTB
Or i'd give Bret at Bauer Racing a hollar, i know he has some designs using the stock TB to support bigger cubes and a aftermarket style manifold
The torque curve looks like that due to the stock manifold having the highest boost in the TQ curve in that spot, When you properly design a manifold for a specific RPM peak rang,it will alter the curve in a different area.
Like I said before,this is being listed as a RACE manifold for 6500+RPM and big motors. The throttle body choice was determined by the design of the plenum, The first version used a stock T\B and had some quirks.
THat was funny. TIm and his 9 second T/a
I think plastic would be best for most people.
