POLL, plastic or aluminum version of FMS intake?
Old Sep 1, 2003 | 07:37 AM
  #101
LS1derfull's Avatar
Default Re: POLL,plastic or aluminum version of intake?
I would want plastic, what size cam is that dyno graph using? The Moore perf. sheetmetal intake moved power band way up on the 427" magazine article, im just curious if this Futral intake has same capabilities?
Old Sep 1, 2003 | 09:55 AM
  #102
99 Black Bird T/A's Avatar
I'm sure Futral is sick of this but...when will the new intake be out?
Old Sep 1, 2003 | 02:05 PM
  #103
ScreaminSS01's Avatar
Good question.Cool weather is coming soon for us in the NE
Old Sep 1, 2003 | 05:33 PM
  #104
lsx24's Avatar
Just saw this thread, I thought I would post some thoughts and opinions.
He said this intake will be good for engines over 6.5k...so, that means for most of us it would not add anything to a H/C car with stock cubes.
The graph supports this, showing an increase in very high RPMs only. I'm not sure a non-solid roller can safely spin this high...(?)
Lastly, from Absolutes recent numbers of the ls6 intake flowed with heads, it looks like the ls6 intake is a bottleneck at all lift specs. Thus it is not able to support good heads anywhere in the lift range. This new intake looks like it has the same characteristics, except it doesn't bottleneck at high lift/RPM like the ls6 intake.
So, I'm just thinking this intake will work really well on the application listed, that's all.
Old Sep 1, 2003 | 06:45 PM
  #105
LS1derfull's Avatar
So no one knows what size cam thats used on this graph?
Old Sep 1, 2003 | 06:47 PM
  #106
Futral's Avatar
Hey guys,sorry I haven't posted anything else about the progess. The outlook of plastic versions is not looking good at this point. Between finding companys to do this type of molding in one piece and cost of tooling($$$$). But Iam still working on it.
So I will be talking to some sheetmeatl intake manufacters and work with them and will try to have some more info soon.
On the subject of working on normal hydralic H\C motors,this intake is not a short runner intake which will hurt midrange torque to a degree. Please just understand,we are listing this intake as a race intake.
We should be done with final testing on various setups soon,and will post the results.
Cam specs...240\244 solid roller
Old Sep 1, 2003 | 07:00 PM
  #107
Slow Z28's Avatar
you get any idea on $$ for the sheetmetal? we are bugging you with this stuff
Old Sep 1, 2003 | 07:27 PM
  #108
Any possibility instead of doing injection molded plastic, doing a casting in a resin of some sort? Some resins will allow simpler/easier to make molds than injection molding does.
