Comp 918 Blu Stripe check in..
Old Jun 23, 2003 | 08:51 AM
m1key99WS6's Avatar
Default Re: Comp 918 Blu Stripe check in..
I've got over 20K miles on my 918's (over 100 track passes) with that .580 cam I got from you (JPR) and it's still running strong, no issues yet.
Old Jun 23, 2003 | 09:13 AM
Rod's Avatar
Rod
did you buy the whole spring kit from isky, with the new spring base? i have seen the spring kit and without the matching spring base the dampner is put in a premature bind, as in with the stock one.did you break a spring or the dampner?
Old Jun 23, 2003 | 09:22 AM
NHRATA01's Avatar
Great thread, I've been looking to see how 918s are doing.
I've got 16k miles on my pre-stripe 918s (I got them back in nov '01, which I believe was right before the bad batch came out) with a little T1 cam. About 30 passes, and no issues so far. Thinking about having a couple pulled off an checked for seat pressure soon.
Old Jun 23, 2003 | 04:10 PM
cantdrv65's Avatar
Prestripe 918's here running .563/.567 lift....8000 miles with no problems whatsoever.
Old Jun 24, 2003 | 09:03 AM
teresa's Avatar
hey joe those springs with the litegreen strip
are manley 221423 t-retainer 23632 good to 600
lift coil bined 1.100 i have 2000 miles on them
with 595 lift(pushing it) there still in one peice
just to let you know
Old Jun 24, 2003 | 09:09 AM
SouthFL.02.SS's Avatar
!LS1 11 Second Club
Just put in my set of 918's...
Old Jun 24, 2003 | 12:30 PM
RB185AFM's Avatar
10,000 miles on my pre-blue stripe 918's. 8,000 miles with TR 220 cam and 2,000 miles with ASA cam rev to 6,600 rpm. No issues here. But then my lift now is only .525.
Old Jun 24, 2003 | 06:53 PM
Quiksilver's Avatar
i bought 918's but decided on a bigger cam w/ a 595 lift, i dont wanna risk it so im going w/ the rev dual springs. Do you guys agree w/ my decision? heres the cam specs 228/236 588/595 114.
Old Jun 24, 2003 | 09:10 PM
JPR's Avatar
JPR
Thanks for all the input guy's, I think I'm going to go with the Rev's though. Big thanks to Comp for stepping up with the new 918's that seem to be trouble free now .
Silver,
You can probably go with the 918's without any problems.
Joe.
Old Jun 25, 2003 | 08:45 AM
HOSS99's Avatar
I have about 2K on my pre-bluestripe 918's purchased 01/02, with a B1 cam. So far no problems.
