View Poll Results: 414cid LS2 Aluminium Stroker Long Block or Ls1 H/C
Ls1 with H/C
8
22.86%
27
77.14%
Voters: 35. You may not vote on this poll
414cid LS2 Aluminium Stroker or H/C Ls1??
Old 11-26-2007, 03:00 PM
Asmodeus's Avatar
Originally Posted by tilly
Those heads will bolt right on but they were designed for a smaller bore. You would have to have the heads reworked so it would fit on a motor with a bigger bore.
You don't have to have the heads reworked for the bigger bore, just make sure the gasket matches the biggest part.. in this case, the bore. You don't want it protruding into the combustion chamber, but people have been using their stock and LS6 ported heads on irn block strokers for a long time.
Old 11-26-2007, 03:14 PM
RareBreed0295's Avatar
But i will still not get maximum potential out of the 5.3s right? i want to get the maximum potential out of the setup if i am going to be spending this kind of money.
Old 11-26-2007, 09:44 PM
Asmodeus's Avatar
oh, if you want maximum, then go for the ETP canted valve heads for your 402. Only about 7000 bucks for heads.
Old 11-26-2007, 09:50 PM
Now i dont got that kind of money.
Old 11-27-2007, 12:27 AM
kistlerjm9's Avatar
l92/l76 setups have been making nice torque numbers def the best bang for the buck. just my opinion and you can always save and move to the ls7 setup later. go with the 408. hell go with the lsx 454 than well talk about torque.
Old 11-27-2007, 06:49 AM
Just got a good offer on a D1SC Procharger setup...looking into that right now...So many ways to go
Old 11-27-2007, 07:08 AM
Mike@HSW's Avatar
Originally Posted by SmokinU
Ok... To go a cheaper route then the 408 low compression and a nitrous setup would work best. If you had an addtional say 3-6g you can go FI on the 408. You can do many setups on the 408 just depends on what you want to do... But if you do not plan on going forged and jsut an ls2 vs ls1 block be very careful. The LS1 block is actaully a stronger block and can withsatand the bigger numbers better. Many options out there. First is to decide the budget and go from there.
nitrous likes compression, lower compression would only hurt you.
I would check out that procharger and see what kind of deal you can get for it. it wont hurt to at least look into it. i still think the best route would be a 383 forged shortblock, it would work well with the heads you already have and then just throw in some nitrous. If you do go with the procharger stick with smaller cubes. keep in mind you wont be able to just buy the procharger, you'll need a fuel system upgrade. again, 383 with nitrous will leave plently of room in your budget to get a 9inch or dana60
Old 11-27-2007, 07:30 AM
What other upgrades will i need besides the procharger setup?
Old 11-27-2007, 05:26 PM
pdd
pdd's Avatar
414 stroker
Old 11-27-2007, 05:29 PM
Yea ive decided to either do the 408 stroker or the Procharger..just doing a bit of research. I want to do the 408 because my ls1 has 80k miles on it now. But then again, i think the procharger will produce more power.
Old 11-27-2007, 05:39 PM
Mike@HSW's Avatar
is that in your budget, your probably looking at at least 10K
Old 11-27-2007, 05:47 PM
  #32
Well TSP sells the complete longblock for like 7k so i think i can do it a little cheaper than 10k.
Old 11-27-2007, 05:49 PM
  #33
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Bigger Cubes..
Old 11-27-2007, 05:51 PM
  #34
Why do you say bigger cubes? What reasons for it over the procharger?
Old 11-27-2007, 07:17 PM
  #35
MPM IV's Avatar
I like big cubes also. The more you add to anything the more there is to break and be in the way. With cubes there is no belt to slip etc. A well built stoker will make big power. When you get used to that you can spray it. I've never had a F/I car, so take my opinion w/ a grain of salt.
Old 11-27-2007, 07:20 PM
  #36
Mike@HSW's Avatar
Sorry i misread, thought you said the 408 AND procharger. i would definitly go with the 408
Old 11-27-2007, 07:25 PM
  #37
How much could i put to the ground if i got it with the l92 heads and a custom grind cam. I just want a torque monster.
Old 11-27-2007, 07:32 PM
  #38
Jpr5690's Avatar
Definately Get The Short Block ... Gives More Room To Gorw And Eventually More Power
Old 11-27-2007, 07:42 PM
  #39
Will my ls1 parts transfer to the ls2 motor?
Old 11-27-2007, 07:49 PM
  #40
jeremym's Avatar
I have a 414c 6.0 iron block with TEA/TFS 235cc heads. Cam specs are 244/248...612/615.. I make 550rwhp 510rwtq thru a 6spd street car. I make 475rwtq at 3000RPM.
Quick Reply: 414cid LS2 Aluminium Stroker or H/C Ls1??
