Stealth II cam?
Old Dec 4, 2007 | 01:33 PM
  #41
PREDATOR-Z's Avatar
For a Procharged you need more exhaust split.
This would work well in certain Turbo app.
Old Dec 4, 2007 | 03:22 PM
  #42
Zach@MTI's Avatar
Originally Posted by SSpdDmon
Would this be considered a good cam for a Procharged application or is the intake lobe too aggressive?
We have installed many magnacharer/procharger systems on cars that already had the Stealth II camshaft installed and they have all made great power. If installing a cam at the same time or after a supercharger is installed we normally use our G1 camshaft 228/232 113 or 115LSA which is excellent in a supercharged applications.
Old Dec 4, 2007 | 03:49 PM
  #43
BarneyMobile's Avatar
I placed an order in with MTI yesterday on my lunch break for the Stealth2 cam, I also bought springs and pushrods from them. I cant wait to get everything!
Old Dec 5, 2007 | 11:33 AM
  #44
Zach@MTI's Avatar
Your buisness is much appreciated, I am sure you will be pleased with the camshaft!! I threw in some liscense plate frames with the order
Old Feb 17, 2008 | 12:26 AM
  #45
I've had the stealth2 cam in the car for about a month now along with the addition of LT headers catted y-pipe LM1, 3.90 gears and typhoon intake. I must say, the car pulls like a freight train! I absolutely love this cam. It drives just like stock with more power. With a catted y-pipe, you cant tell the car even has a cam. I caught a few people off gaurd thinking all I had was just a cat-back exhaust The car is getting dyno tuned soon so I'll have some numbers to put up. I still have a few other bolt-ons I want to add on. Soon I will also be adding a set of ported 5.3l heads.
Thanks again to the guys at MTI, you guys are awsome!
Old Feb 17, 2008 | 04:59 AM
  #46
Street Lethal's Avatar
Real testing comes next month, see you at the track....
Old Feb 17, 2008 | 09:25 AM
  #47
hirdlej's Avatar
So when can we expect that you'll post up some sound clips for us? Both idling and revving? Also we want dyno numbers and graphs after it's tuned
Old Feb 29, 2008 | 08:16 PM
  #48
I just got back from the dyno. I made 381.27rwhp and 364.50rwtq I still have to get my graph scanned but for now I going out and enjoying it
 Michael S. Palmer
Old Mar 26, 2008 | 05:09 AM
  #49
wesam's Avatar
this is my dyno Number with MTI stealth II heads and full boltons
[IMG][/IMG]
my setup is :
2004 GTO A4
Kooks 1 3/4 LTs with cats
MTI stealth 2 224-220 .581-.581 116
Patriot LS6 stage 2 heads 59cc
Comp Hydrolic lifters
SLP 7400 push rods
SLP Oil Pump and Timing Chain
Vig 2800 TC
FAST 90 intake manifold with
FAST 90 TB
160 thermostat
MSD wires
NGK tr55 plugs
Transgo shift kit
Flex-A-Lite transmission cooler
SureFlo OTRCAI
SLP underdrive pulley
SureFlo catback with X-pipe
Mobil 1 oil
difftechnics 3.73 ratio
Any comments
Old Mar 30, 2008 | 07:50 PM
  #50
Blk_Ws6's Avatar
I have the cheatr cam with a custom tune ,asp pulley,mac y pipe with stock manifolds,700r4 tranny with vacuum modulator,ported ls6 heads,ls6 intake,gms maf sensor,blackwing airbox,and 342.gear ratio and I can beat a 2006 corvette by a car 1/2 didn't bring it to the track yet .
Old Mar 30, 2008 | 07:54 PM
  #51
Blk_Ws6's Avatar
2000 ws6 a4
Old Mar 30, 2008 | 10:35 PM
  #52
eamador11's Avatar
Would I be better off going with the stealth2 since I putting LT headers on?
yes,cheater was designed for stock manifolds.
Old Mar 31, 2008 | 09:30 AM
  #53
Zach@MTI's Avatar
[IMG][/IMG]
my setup is :
2004 GTO A4
SLP 7400 push rods
Vig 2800 TC
FAST 90 TB
160 thermostat
MSD wires
NGK tr55 plugs
Transgo shift kit
SureFlo OTRCAI
Mobil 1 oil
Any comments
Thanks for posting up! Those are good numbers through cats and A4
Zach
Old Apr 3, 2008 | 07:45 AM
  #54
fortmyerspolice's Avatar
Originally Posted by PREDATOR-Z
Or custom Stealth:
224/220 .604/.581 115+2 LSA
XFI/XE-R
A slight variation of Stealth 2 with a bit earlier powerband.
I had the Stealth 2 in 2 combos and Head/Cam + bolt ons I got best of 11.2 @ 120 mph (Auto with VIG 3200)
I'm gonna try this cam out
Old Apr 3, 2008 | 12:36 PM
  #55
BlackNiteWS6's Avatar
I called both TR and MTI about the CheaTR and the Stealth2. I've narrowed down my search to these 2 cams. Now my problem is which one? They both claim about 40rwhp gain with supporting mods which I will have. Maybe I'll just flip a coin, what you guys think?
They both claimed 40 hp? The CheaTR cam has almost 10 degrees less duration than the Stealth II cam. Is this really the case?
Old May 6, 2008 | 05:39 PM
  #56
onecamaro1's Avatar
[IMG][/IMG]
my setup is :
2004 GTO A4
SLP 7400 push rods
Vig 2800 TC
FAST 90 TB
160 thermostat
MSD wires
NGK tr55 plugs
Transgo shift kit
SureFlo OTRCAI
Mobil 1 oil
Any comments
I was also wanting a stealth 2 cam, but i'm worried about the torque loss on both ends compared to my graph, here is one of my off days but tq is over 300 from under 2500 till the end and don't worry about the afr, its been fixed.....new #'s in sig. Curve is still the same though.
i still want a bigger stealth street cam 6500rpm max with no loss anywhere even if the gains aren't as high as they could be.
Old May 6, 2008 | 05:48 PM
  #57
onecamaro1's Avatar
Nvm, i see the torque numbers on the right.
