Stealth II cam?
Old Nov 29, 2007 | 12:21 AM
BarneyMobile's Avatar
Default Stealth II cam?
I've been on the hunt for an good sleeper cam. At first I was thinking the TR224 on a 114LSA, or TSP 224R 116LSA. Then I came across the MTI stealth II cam. I've read that it rivals largers cams in power with out the loppy sound at ilde. I want my car to sound like it only has bolt-ons.
I will soon be installing some LT headers and an LS6 intake. How much power can I expect from the Stealth II cam? Are there any other cams out there that will get me more power and a stealthy idle than the stealth II cam? Let me know what you guys think!
Old Nov 29, 2007 | 02:32 AM
COD02SS's Avatar
May i also suggest looking into the "CheaTR" Cam from thunder racing
Old Nov 29, 2007 | 06:12 AM
PREDATOR-Z's Avatar
Or custom Stealth:
224/220 .604/.581 115+2 LSA
XFI/XE-R
A slight variation of Stealth 2 with a bit earlier powerband.
I had the Stealth 2 in 2 combos and Head/Cam + bolt ons I got best of 11.2 @ 120 mph (Auto with VIG 3200)
Old Nov 29, 2007 | 09:46 AM
Stealth 2 vs. CheaTR cam, which one will put down more power and how much will they put down on stock 853 casting heads and mild bolt-ons?
Old Nov 29, 2007 | 10:07 AM
99 Pewter TA's Avatar
I put 407rwhp down with Stealth II & port 241 heads. This was done with mac mid tube headers through carsound cats. It is a sleeper cam for sure. My buddy put down 385rwhp this stock heads.
Old Nov 29, 2007 | 10:22 AM
I'd be more than happy with 370rwhp.
Old Nov 29, 2007 | 10:27 AM
Zach@MTI's Avatar
With the right combination 400+rwhp is achievable with the stock idling Stealth II....It is THE best stock idling cam out there.
Old Nov 29, 2007 | 05:32 PM
RE AND CHERYL's Avatar
That's funny stuff. I said the EXACT same thing this summer when I swaped in my LS1 with a Stealth II and MAC mids. Now I have a set of ported Stage II 5.3 heads and merged stainless LT headers in the garage waiting to go on this winter. The Stealth II should make around 370-380rwhp without heads and a little north of 400rwhp with a full on effort. The cam runs awsome and is almost undetectable as the idle sounds stock for the most part.
It faster than it sounds
Re'
Old Nov 29, 2007 | 06:41 PM
91_RS_LS1's Avatar
Originally Posted by PREDATOR-Z
Or custom Stealth:
XFI/XE-R
Hmm.... where would one purchase such a cam?
Seems like this cam would benefit a set of CNC'd heads more than the standard Stealth II. Would a greater lift on the exhaust improve power without making it obvious it's cammed?
May go through MTI when I get my swap in.
Old Nov 29, 2007 | 11:27 PM
I called both TR and MTI about the CheaTR and the Stealth2. I've narrowed down my search to these 2 cams. Now my problem is which one? They both claim about 40rwhp gain with supporting mods which I will have. Maybe I'll just flip a coin, what you guys think?
Old Nov 30, 2007 | 03:17 PM
Would I be better off going with the stealth2 since I putting LT headers on?
Old Nov 30, 2007 | 03:23 PM
Kent1's Avatar
Most likely the Stealth 2 since you will be installing the headers.
Old Nov 30, 2007 | 03:28 PM
3rdgentug's Avatar
i like the specs on predator z's cam
id get in touch w/ patrick g and see what he thinks, he could grind it for ya!
Old Nov 30, 2007 | 05:01 PM
massls1guy's Avatar
Re'
I hear you. Power is addicting.
Old Nov 30, 2007 | 05:26 PM
Street Lethal's Avatar
Originally Posted by 3rdgentug
i like the specs on predator z's cam...
So do I....
Old Nov 30, 2007 | 05:39 PM
Zach@MTI's Avatar
We have tested higher lift versions of the Stealth II camshaft such as what was proposed by Predator-Z and they made virtually ZERO difference in the amount and the way they made power....so why run more lift and more aggressive lobes when it makes no difference in this application??
Old Nov 30, 2007 | 06:25 PM
TXZ28LS1's Avatar
id go with the stealth cam from MTI. i believe the cheatr cam is more intended for stock exhaust also i think.. not so sure.
Old Nov 30, 2007 | 08:24 PM
91_RS_LS1's Avatar
Question
I'll admit I don't know much about cam design, but I would think if one were running heads that had max flow at or above .600 lift that a cam with max lift at ~ .600 would make more power than a cam with .581 lift. Then again, it's only .020 of an inch
Old Dec 1, 2007 | 08:44 AM
PREDATOR-Z's Avatar
I beg to differ on that one, I have ran your Stealth 2 back in the days that Colonel (pioneer) just had it installed. I've had it in 2 different combos, 1 as cam only and one with heads. Good cam no doubt about it.
But, lately I just used a 224/222 XFI/XE-R(actualy 225/223 once ground) and it made ~ 10 rwhp more cam only, so if you tailor the combo with the right valve events it will make more power.
So you statement is incorrect.
Old Dec 1, 2007 | 09:40 AM
52172's Avatar
well there can be a lot of different variables for that extra 10 hp like dynoed on a different day with different weather conditions and also it probibly was a different car and motor so MTI and predator z both have opinions and no one can be 100 percent sure unless both cams were dynoed back to back on the same day with the same car and both tuned for each cam.
