243 Heads
Old Nov 29, 2007 | 01:43 PM
GreatWhiteHype01's Avatar
Talking 243 Heads
Will 243 heads from the C5 Z06 mount on the 3.9" bore LS1 found in the 98-02 Camaro/Firebird? If so is there a substantial gain found in them over the 241 LS1 heads? I am looking at a set that are brand new LS6 heads (243 casting), Stage 1 ported by Livernois Motorsports. Assembled with stock LS6 valves, retainers and springs, stock chamber size. Any suggestions? Thanks. -Tom.
Old Nov 29, 2007 | 01:45 PM
12secSS's Avatar
Those heads were first introduced on 2001 LS6 engines, so yeah they will work on an LS1 (3.89" bore). You should see about 10-20 hp increase with stock 243 heads over 241 heads. With ported ones, you can see as much as 25-30.
Old Nov 29, 2007 | 01:56 PM
DANOZ28's Avatar
i think 98 heads have a different bolt pattern. but 99-2002 should be fine. the positive with actual vette heads is they come with light weight sodium filled valves (not sure if both exhaust & intake). however right now one of our sponsors is running a special on ls6 heads (w steel valves). i believe stock 241 heads flow about 245 cfm, stock ls6 flow about 265. and ported heads flow over 300 plus.
Old Nov 29, 2007 | 02:10 PM
DANOZ28's Avatar
prt 2 i mistake i felt i made was not upgrading the ls6 standard springs to say patriot gold (good to 650 lift cams) if nothing else its added insurance.
Old Nov 29, 2007 | 02:17 PM
Bad Blue WS6's Avatar
the different bolt pattern is the valve covers only.
Old Nov 30, 2007 | 09:08 AM
radkon's Avatar
This may help:
Old Nov 30, 2007 | 09:20 AM
LivernoisMotorsports's Avatar
The heads will bolt onto any LS1 engine, however as others have mentioned the '98 cars will require different valve covers and coil packs.
Regards,
Rick LeBlanc
Old Nov 30, 2007 | 11:41 AM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
Finally I'm going to save that graph for future newbie questions.
Old Nov 30, 2007 | 12:47 PM
TARZAN's Avatar
Yes, they'll fit, and with a tune, they should provide noticeable gains.
-Will
Old Dec 1, 2007 | 03:17 PM
Chucks1911's Avatar
Very helpful chart radkon. Thanks for posting it.
Old Dec 1, 2007 | 05:55 PM
Jray67's Avatar
The hollow stem valves only cam in a few select years. 02-04 I believe, but don't hold me to those years. The recent 243 heads have solid valves. I have a set of 243 Stage I's from Livernois and they have solid stock LS6 valves.
Old Dec 1, 2007 | 05:59 PM
Jray67's Avatar
Livernois is a great company with great customer service. I talk to Mike there whenever I call. He answers all my questions and he's as nice as can be. I highly suggest them. You won't be disappointed.
Old Dec 3, 2007 | 12:06 PM
radkon's Avatar
You're right, the hollow stem valves are only in the LS6 Z06 package. The 243's in the GTO and later heads are solid.
I don't remember where I found that chart but its very helpful!
Old Dec 3, 2007 | 02:53 PM
quiet_storm98's Avatar
stock heads dont flow that well...more like low 200's to 220 or so cfm
Old Dec 3, 2007 | 03:08 PM
Thorny's Avatar
It looks like the one from GMPP's performance catalog. I believe they have the flow numbers for thier different heads on there as well. The website that I know its on isn't a sponser here, so I won't post a link,but it should be available elsewhere too.
Old Dec 5, 2007 | 01:22 PM
Dokken's Avatar
Thumbs up
Thanks for sharing this info
