milling vs combustion chamber ....
Old Nov 30, 2007 | 08:20 AM
teke184's Avatar
Default milling vs combustion chamber ....
is there a benefit to one head over the other:
- both heads flow the same cfm
- both have the same intake runner (and exhaust for that matter) volume
one head is milled to 59cc
one head has the chamber design for 59cc
*assuming both allow for proper PTV clearance**
Old Nov 30, 2007 | 08:39 AM
GuitsBoy's Avatar
P to V clearance is the big one. And milling too much starts to impact flow. Shouldn't really be noticeable unless to mill quite a bit.
Old Nov 30, 2007 | 09:00 AM
radkon's Avatar
+ 1 if they both flow the same then P 2 V is the only concern. If they are the same (tough in this situation) head and one is milled then flow is affected.
Old Nov 30, 2007 | 11:48 AM
teke184's Avatar
gotcha...thanks.
i hear terms like "quench" and "shrouding the valves"....or was it the plug?
wondering how those thing played into the mix.
Old Nov 30, 2007 | 12:45 PM
TARZAN's Avatar
What was it milled down from?
-Will
Old Nov 30, 2007 | 01:28 PM
teke184's Avatar
what was WHAT milled down from??
these are hypothetical heads that i'm talking about.
but i was referenceing milling 241s down (and in conjunction with the gasket) making a 59cc chamber....like that of the 5.3L heads
Old Nov 30, 2007 | 02:59 PM
GuitsBoy's Avatar
quench is changed via gasket thickness or piston out of hole height, not milling.
Old Nov 30, 2007 | 03:13 PM
ssheets's Avatar
Wouldn't valvetrain geometry be the other thing that is affected?
I.E. a 5.3 head has the same valvetrain geometry as a 5.7 head, but the chamber ceiling is .030 (or .035") lower. (the 5.3s have smaller intake valves). So in rough theory, you can mill a 5.7 head and have the same cc that a 5.3 head has, but now your valvetrain is closer to your cam so your pushrod length will have to be changed. Your intake port to intake manifold will change accordingly too.
That's my 02 cents
Old Dec 3, 2007 | 12:11 PM
radkon's Avatar
I.E. a 5.3 head has the same valvetrain geometry as a 5.7 head, but the chamber ceiling is .030 (or .035") lower. (the 5.3s have smaller intake valves). So in rough theory, you can mill a 5.7 head and have the same cc that a 5.3 head has, but now your valvetrain is closer to your cam so your pushrod length will have to be changed. Your intake port to intake manifold will change accordingly too.That's my 02 cents
You are right, at a minimum you'll need shorter pushrods. The (new) gaskets on the intake should be able to accommodate the change.
