Anyone try this cam?
Old Jun 24, 2003 | 09:16 AM
RoyO's Avatar
Default Anyone try this cam?
I was searching around the Comp Cams web site and ran across this grind..
Xtreme Rpm 54-424-11
.558/.563 lift int/exh
212/218 dur @.050
115lsa
It looks like a nice street cam thats just a bit more aggressive than a 02LS6 grind. Im gonna try it I think.
It also says it has a power band of 1400 to 6700rpms.What do you guys think.TIA.
Old Jun 24, 2003 | 09:54 AM
Cal's Avatar
Cal
Default Re: Anyone try this cam?
You already have a TR224 and you want to down-grade?
Old Jun 24, 2003 | 10:47 AM
RoyO's Avatar
Im kinda detuning the car cause Im not going any further with it. I also gotta worry about passing emmisions now. Conneticut is starting its test up this fall and Im pretty sure the cam wont pass.
Old Jun 24, 2003 | 10:49 AM
JayLS1-327's Avatar
I think with an orp you will not pass with any cam.
Old Jun 24, 2003 | 11:01 AM
Cal's Avatar
Cal
That's true cats do a lot to clean up emissions. A lot of people pass emissions with the TR224 and cats. I'd put cats back on before I'd dump the cam. A good PCM tune should help you to pass as well.
Old Jun 24, 2003 | 11:34 AM
Smoke_Ford's Avatar
Dont they just plug cars that are 96 and newer? If you car is tuned right, they wont even sniff it.
Old Jun 24, 2003 | 11:36 AM
boomcase's Avatar
Antta99 , I was looking at that cam but didnt like the RPM range, they are supposed to start up the emisions this fall , just like they where in may. will have to see though, I just purchased a comp 216/220 cam I think when the time comes it should pass, Dam I hope so.
Old Jun 24, 2003 | 12:02 PM
RoyO's Avatar
Its something different and with the mild duration it should pass no problem.
