ls1 removel
Old Jun 24, 2003 | 07:14 PM
PUREEVIL98's Avatar
Default ls1 removel
I AM GETTING READY TO REPLACE MY MOTOR. I WILL BE TAKING IT OUT FROM THE TOP. WHAT WOULD BE THE EAZYEST WAY TO REMOVE THE ENGINE? WITH OR WITHOUT THE TRANNY? ANY TIPS TO MAKE THIS EAZYER WOULD BE GREAT. THANKS DAVID.
Old Jun 24, 2003 | 07:34 PM
Country Boy's Avatar
Senior Member
Default Re: ls1 removel
I did mine without, but I believe it can be done with.
Old Jun 24, 2003 | 07:36 PM
Assassin's Avatar
it'd make life easier if you take it out without the tranny, especially if you're working in a tight area, only add time for removal of tranny!,
Old Jun 24, 2003 | 07:48 PM
PUREEVIL98's Avatar
THANKS FOR THE INFO. I WAS THINKING IT MITE BE EAZYER, DO TO THE FACT IM TRING TO THINK HOW TO GET THE UPPER BELLHOUSING BOLTS OUT IN SUCH A TIGHT SPOT. DOES ANYONE KNOW THE BEST WAY TO GET TO THEM? THIS IS THE FRIST LS1 I WILL BE PULLING OUT.
Old Jun 24, 2003 | 08:28 PM
LS1x2's Avatar
Formerly 4mulaJoe
I think it's easier with it attached. You just have to get the hoist at the right angle and it all comes out.
Old Jun 24, 2003 | 08:31 PM
Slow Z28's Avatar
same here, i removed the heads/intake, and then i took out the shortblock/trans together with the hood still on. was a little process, but after i got the heads/intake removed, probably took 30 minutes to get it out and squared away.
Old Jun 24, 2003 | 08:32 PM
Senior Member
To get the bellhousing bolts out, just remove the tranny, and let the engine lean back as far as it will and ues ALOT of extensions and a swivel
Old Jun 24, 2003 | 09:22 PM
BYBYC5's Avatar
*Bad Trader*
ive done it 4 times on my car, remove heads and intake,headres, then you can see and remove all the top tranny bolts, i didnt realize this til the last time tho. when the motor is ready to pull, and only then, unbolt the motor mounts from the motor AND the KMember, as soon as you move the engine they will drop out of the way...the 3rd/4th time i left most of the accy. on the front but the Crank pully MUST come off.
Old Jun 24, 2003 | 09:51 PM
Slow Z28's Avatar
do you mean you left the radiator in? cause i got all my stuff out with the crank pulley still on? but all my stuff forward of the motor was out
Chris
Old Jun 24, 2003 | 09:55 PM
DERTY's Avatar
The Bull
The block will come out with the heads on it. The crank pulley needs to come off. If you pull the hood off you might be able to get the trans out. Otherwise, just spend the 15 minutes and pull off the trans first. 3' of extension and a swivel and you can reach the upper bolt. Even easier if you save the trans for last and drop the motor mounts while holding it with a hoist and jack. Pretty easy.
Old Jun 24, 2003 | 10:29 PM
BYBYC5's Avatar
*Bad Trader*
yes the block will come out with the heads on but its really easy to get the top 3 tranny bolts without them,
no the radiator was taken out but its easier to get out with out it, i guess it wouldnt matter..
Old Jun 24, 2003 | 11:25 PM
Bad1le's Avatar
I pulled mine from the top w/ the tranny attached! Heads and ASP pulley stayed on and it cleared just fine. I did pull all of the accessories off though. Hell of alot easier to pull the heads off when the motor is out of the car IMHO.
AJ
Old Jun 25, 2003 | 01:46 AM
CAT3's Avatar
Restricted User
dayum you guys make me wanna pull mine to see how long it takes me and to clean the dayum thing. good lord that sounds easy.
Old Jun 25, 2003 | 07:12 PM
PUREEVIL98's Avatar
thanks again for the info. once i get the new motor in and installed. i will give you my time. thanks david.
Old Jun 25, 2003 | 07:45 PM
2001CamaroGuy's Avatar
I would pull it with the tranny.....just slide the entire unit out the top.....
Old Jun 25, 2003 | 07:48 PM
highgmc's Avatar
removed my radiator, accessories, intake, hood and removed my motor and trans together, EASILY
